Nexxt 100 Series Washer
I recently purchased a front load washing machine. We are finding when we have towels washing that the washser freqently stops, the start button beeps until someone presses it. I just finished a load and this occurred 5 times.
The wash has a mixture of towels and cloths.
  • 213 Answers
Seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Posted on Nov 20, 2007
How do I replace the motor control board on my own & where is the best place to purchase this part?
try eSpares. Bosch parts are expensive but alternatives are usually available. They also have video tutorials for fixing common problems. Bosch website usualy has diagrams in the spares section. Are you 100% sure it is the control board? It could be something else causing the control board to freeze. For example I recently had to replace the drain pump on our machine.
Oct 20, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
When washing towels the load starts banging...not overloaded and repair service can't find the issue.
sounds like a broken shock,or balance spring!! possibly loose concrete weight on tub
Mar 15, 2013 | GE WSXH208A Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer wont spin belt is on pump is free of debris
Possible that the main motor is jammed or does not get power from the program controller unit. It is important that you measure the voltage at the motor when the program is set to start after the inlet valve fills water. If there is no voltage then the program controller unit is faulty.
Click this link for support : washing machine tips
Jun 25, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My dryer starts up for less than a minute and than starts beeping and all lights start flashing. For a while i was able to change settings from 60 mns to towels and it would work. Now it starts for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 10, 2010 | Dryers
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
