Question about Disney DVD2100-P DVD Player/VCR
Our dvd2100-pa will not close. how do i fix it?
Our dvd2100-pa the dvd drawer will not close all the way, we push hte button to close and it goes in a little bit but then gets stuck. how do i fix it?
    Problem Solver:
  • 6 Answers
I would try to push it manually but very gently so not to force it. I used to have this problem and I pushed it in with my hands and it worked. I hope it works for you.
Posted on Jun 30, 2009
How do I fix my computer CD writer Drawer to make it open.I banged it with my knee when it was open,I pushed it closed and does not open any longer.Its the HP 583 Pavillian model,not new but works wel
Many times you will see a small hole next to drawer, try something thin lika a paperclip & give a gentle poke inside. Feel for a button type spring response.
Oct 15, 2014 | Computers & Internet
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
My LG dv490h DVD player has its DVD drawer jammed open. When I press the button to close, it goes 20% of the way in and stops. My one year old pulled the drawer open this morning. Have taken the cover off...
The DVD tray has come off the alignment or settings which make it come OFF the mechanism. So you will need to push back the drawer back to the set position and this might be possible only after the loading mechanism is pulled out. The loading gear would have meshed with the loading drawer at mid way -due to the pull--and so it connecting only half way.
If mechanically minded you can remove the tray mechanism and reset the tray to the gear position in the DVD play/stop position.
Feb 04, 2011 | LG DVD 6053 DVD Player
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
My HT-z310 dvd player does not read when i put dvd in
Try manually pushing dvd drawer in after pushing open/close. I opened mine up and noticed the dvd is not spinning - I don't think the drawer is completely closing over. BTW this is not a permanent fix - it doesn't work all the time.
Apr 18, 2010 | Samsung HT-Z310T Theater System
The dvd drawer will not open on Bose 3-2-1 system. When you push the button to open the dvd, the display say ''opening'' but it does not open. There currently is a dvd inside.
That happens when you close the drawer instead of pressing the close button  you can skip gears and it would have to be taken apart and re-calibrated.   Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front  (assuming this uses a drawer).
Nov 09, 2009 | Audio Players & Recorders
The eject button on my VRDMC5 DVD recorder does not work at all.
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Apr 24, 2017 | Sony VRD-MC5 DVD Recorder
DMR-E50 won't eject disc.
Nope sorry no quicky fix here
Sep 19, 2006 | Panasonic DMR-E50 DVD Recorder
Disk drawer won't close
hi first try disconnecting it for a couple of hours and see if it helps if the device is out of warranty then: try pushing the drawer while pressing the play button (like helping it) feel and listen if there is an attempt or a noise indicates that the device is working but something is bad like the engine drawer, a torn belt, a broke cog try fixing it if you can with a new part good luck
Apr 03, 2006 | Panasonic DVD-F87 Multi-disc DVD Player
Disney DVD2100-P DVD Player/VCR Logo
99 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
