Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD 250 G hard drive will not turn on at work
My WD 250 G hard drive works fine at home, but will not turn on when connected to my office computer. It is plugged in and connected through the USB port. What do I need to do?
    Scholar:
  • 38 Answers
If that is the case and it works on another PC, your office PC may either..
Not have USB driver installed, and therefor cannot connect to it. I suggest running Windows Update>Custom Update, and under HardWare I imagine there should be an USB driver of some sort. That may fix the problem.
Another issue could be that the USB port has a hard ware failure. Try the other USB ports, if still nothing then it is most likely going to be a driver issue or maybe... all your USB ports have a Hard Ware failure of some sort.
You can check if you need drivers by going to Start>(Right Click)My Computer>Properties>Device Manager Tab. If there are any yellow or ! drivers, you will need to find them via Microsoft Updates, Manufacture/PC Brand Site (I.E HP) or google the driver needed for your particular modeled machine.
I hope I have been of some assistance.
Posted on Jun 30, 2009
This happened on my computer randomly where the drive would only power on momentarily if you unplugged it and re-plugged it either tot he computer or the power source. It did however, work on my other computer. I followed the instructions of Inzanio09 to the device manager tab, and my solution was a bit more simple. It turned out that the drive was just somehow disabled. (red x over it) All i did was clicked the button above to enable and got all my music back! Thanks for getting me that far Inxanio09.
Posted on Jul 07, 2009
    Scholar:
  • 78 Answers
I believe the MyBook line of products needs to have the software installed on each PC where it is used.
Dropped it once and then it was working but not anymore, when connect to the computer the light is still on but the computer doesn't recognize it.
Hi ,
The best way I can think to recover your data is to extract the HDD from it's box ( box will be lost ) and connect the drive directly inside your desktop .
You could also try a recovery tool , from here for instance
http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
Otherwise , you could ask a recovery office to do the job for you but it will cost you lots of monney .
Best regards .
Feb 01, 2011 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
My computer does not read my external drive (WD MyBook 250 GB). My work computer will not recognize either. It was working fine, but a Firefox crash necessitated a computer restart. After the restart, the...
You don't say which version of Operating system you are using. My thoughts are to first go to "my computer" and see if your drive shows up there. If not, get to disk management and see if it shows up there. The crash possibly could have messed up your external drive, and now it needs to be initialized and/or formatted.
Nov 05, 2017 | Western Digital 250GB MyBook External USB...
External Hard Drive connected but hidden !!!
Connect it to your computer.
Right click on my computer and select Manage
On the left side click on Disk management.
Now on the right side, look around and see if you spot the external drive there.
What do you see there?
Also look into device manager, then look for anything with ! or ? yellow marks.
May 03, 2009 | Western Digital WD Passport 250GB Portable...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
WD2500JB hard drive not recognize. Stop working
It's possible that the controller board on the underside of the drive has failed.
Mar 21, 2009 | Western Digital Caviar SE WD2500JB 250 GB...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
456 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
