Question about Zanussi WJS1397W Front Load Washer / Dryer
How to replace door lock
Have bought a door lock repair kit, but am unable to separate the door to change the handle and latch. How do I separate the door outer part from the glass window from the door inner part?
  • 249 Answers
Posted on Nov 28, 2007
  • eamonn close Dec 21, 2007
    ?which bit don't you understand?
Why will my drivers door not open,even though it locks and unlocks with key fob.
Sounds like the activator rod that goes from the door Handle to the latch is disconnected. You will have to get the door open to repair it and a good mechanic or tow truck driver can use a slim Jim kit to get the latch to release and then you can pull the door panel and find the problem.
Jun 29, 2014 | 1999 Volvo V70
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
Lock faults
test this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more:
Jul 30, 2013 | Sharp Microwave Ovens
How do you replace the front door latch assy on 1995 Ford F150 with power windows and power door locks. I am unable to disconnect the rod that connects the latch / lock to the solenoid so I can remove and...
You will have to cut the rivet holding the lock solenoid,you will need to move the solenoid around to un-hook it from the rod.Be careful because the part the rod hooks to is plastic and i already broke mine on my 1994 Bronco.while replacing the latch,consider replacing the cable for the inside handle-they stretch and makes you pull harder on the handle until it breaks the handle off.I got tired of replacing the plastic handle so i made one out of steel at my work.
Feb 26, 2010 | 1995 Ford F150 Styleside Regular Cab
Unable to open rear nearside door. I have managed to take off the door card and can now see the inside of the door but both the inside and outside door handles appear to be working but the lock mechanism...
Is your car door set up to override the lock mechanism if the door handle is pulled?
If it is not set to override, is your door still locked when you use the handle?
If the door is unlocked, is your door latch in the open position when you test the handle?
If open, close the door latch (not the door, just the latch) and pull the handle to see if this releases.
If it doesn't, check to see if all the rods connecting to the latch mechanism and the handles are all in working order
Sep 08, 2009 | 2000 Jaguar S-Type
Power door lock, driver side only, does not work in my '95 Sable
if you here a noise that should mean the little motor (door lock actuator) thar works the door lock is getting power to it and it should be ok. sounds like when you changed the inside latch you must have disturbrd/disconnected the linkage or the clip that connects the lock actuator to the latch assembly(the female V-SHAPED mechanism that engages the POST/STRIKER (male part) its a little hard to name these parts so i am describing them to you. look insidethe door and see if you see any threaded RODS OR LINKAGES that are not connected at both ends.the noise youre hearing is most likely the door lock actuator "spinning"up and down but its unable to lock or unlock the door latch mechanism.
Sep 01, 2009 | 1994 Mercury Sable
The latch/lock on back door of Mitsubishi Montero SR doesn't work
Open the rear tailgate from the inside. Now open the door to the toolkit that is usually mounted on the tailgate/rear door. Using a large Phillips screw driver[usually a #3 tip], take the tool kit off the door panel by unscrewing/removing the screws holding it to the door itself. Once you have removed the tool kit, use a knife to carefully cut a "U" shaped access flap in the clear plastic sheet that should have been behind your tool kit. This sheet is called a water shedder or water curtain, it keeps water off the back of any door panel trim to prolong its life. You want to cut that U shaped hole in the sheet where the door sheet metal already has a hole from the factory. This will allow you to peek up inside your door and see how much of the rear door handle broke on you.
You should be able to easily see the guts of the rear latch and the release handle from this vantage point. Try to move the handle on the outside of the door. If any linkage or plastic 'arms' broken during your winter, you'll probably see this as well. Hopefully new parts are available, otherwise, you'll need to access a used Montero in a salvage yard to get good working parts as a repair. While you're in the door, lube ALL latch, cable, handle parts with a light oil to help prevent this from happen[the oil or a light grease will help displace any future water or ice from sticking to any latch parts]
You can easily tape the U shaped cover you made of the plastic sheeting back up into place with some decent tape, like Duct tape or packing tape. Masking Tape will work, but falls apart in a car with age. Clear plastic Packing tape works well and is transparent to boot. Good Luck with the door.
Jun 01, 2009 | 1994 Mitsubishi Montero
Door won't unlatch or come open
Ford had a problem with the door handles not working properly. They are cheap plastic. If the exterior door handle is broken, you will need to drill out the rivets that hold it in, and then get the door open and the panel off. You have to disconnect the rod going to it. Then, remove the handle. If you don't want to drill again, I suggest replacing the rivets with a bolt and nut easily obtainable at your hardware store. I've found that a M7 bolt works very well. If you are having a problem with the interior door handle, it's the same problem. Remember to check your door latch because if your exterior handle is broken, then your latch isn't working properly. I got one at Ford for about 40 bucks.
Oct 04, 2008 | 1999 Ford Explorer
Door lock
When the actuator moves the latch up, it connects the outside door handle to the opening mechanism. When the latch is down, the outside door handle is disconnected from the mechanism so that it cannot be opened. So in this case your latch needs to be replaced, the latch or one of its parts is malfunctioning. the outside handle is never beening disconnected from the latch. remove the door panel visually inspect for damage, and take the proper repair
Jul 12, 2008 | 1997 Oldsmobile Cutlass Supreme
Zanussi WJS1397W Front Load Washer / Dryer Logo
108 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
