I need to reset my password
Go to gmail home page and enter user name and password and login then open account setting and change password ..
I assume that you can still access your account with an old password that you need to change. If this is not the case then the procedure is different.
Login to your account and click on the "cogwheel" in the upper right of the gmail box and select settings. When this comes up there is a tab at the top labelled "Accounts & Imports", click on this and the first option is to change your password. Click on this and follow the instructions.
If you have not remembered your password to get in you should go to the sign in page and click on "Need help?" and follow the instructions through. To do this you need to have given Google an alternative email address or some other way of contact to recover your username and/or password when you set the account up.
Good luck
SOURCE: compaq 5000 series need to reset login password locked out
Start your computer in safe mode (tap F8 key when starting up) then log into safe mode as administrator then go to user accounts and remove password from any account set up on computer. Restart and your done.
SOURCE: my pc will not accept my login passwords for none of its accounts
go to safe mode then select the administrator account and go to control panel then select your user account. just remove the password.
SOURCE: If i try to login
Try resetting your browser and also check whether the time & date on your computer is correct.
SOURCE: help me to sine in gmail account
Go to gmail.com and enter your credentials (username and password there). If you're having trouble remembering your password, it should have a "forgot password" option to click on. I believe you have to enter your full email address for your username (i.e, [email protected]).
Occasionally Google Gmail user may want to reset the password which used to login into the Gmail account via web, POP3 and IMAP as the original password has been forgotten, or misplaced. Gmail credentials integrates and bases on Google Account. So changing the password for Gmail will also change the password for the associated Google Account.
In order to reset and change the password of Gmail and corresponding Google Account with the affected Gmail email address, follow these steps:
If you're unable to answer your security question and the account has a secondary email address configured, a link will appear at the bottom of the secret question results page. Clicking on the link will has a password reset email message sent to the secondary email mailbox. After receiving the email, follow the link to reset the password.
If you have login to Gmail in the preceding 24 hours period, the password reset email will be sent immediately instead. Follow the link to reset the password. If you don't have a secondary email address, or if you no longer have access to that account, repeat the steps above after 5 days. At that point, you'll be able to reset your password by answering the security question you provided when you created your account.
