Question about Canon PIXMA MP170 All-In-One InkJet Printer
HOW DO I EMPTY THE WASTE INK SO I CAN PRINT - Canon PIXMA MP170 All-In-One InkJet Printer
Is your question referring to replacing the empty ink cartridges with new ones, or is it regarding having this printer for many years and the ink pad inside has clogged-up and you're now receiving error messages about the pad being full?
Please get to me soon, I'll be happy to help.
Regards.
Posted on Jun 30, 2009
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Not printing all colours, heads clogged? Printing red and blue but not yellow.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. Make sure that the yellow ink is not empty. If it's not empty, head may be clogged.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
If that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 11, 2010 | HP Photosmart D5160 InkJet Printer
How to fix waste in full
Peel too many apples for a Thanksgiving pie, and the "waste" (the apple-peels) will fill your garbage-bin. So, you have to empty-out the garbage-bin, or replace the full garbage-bin with a brand-new _empty_ garbage bin.
Print too many pages, and the "waste" ink will fill the miniature waste-bin inside the printer. Take the printer to a qualified technician, and have him/her either empty the bin, or replace the sponge in the bin with a fresh sponge.
Nov 25, 2009 | Cannon MULTIPASS C530 Printer
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Reload the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA MP170 All-In-One InkJet Printer Logo
old marine
old marine
