Question about Refrigerators
Coil freezes up Its an amana refrigerator 1st edition It appears as if the defrost heater is not working. All wiring and connections look ok to the defrost heater and what appears to be the defrost timer.
  • 11,896 Answers
It is probably the heater itself. The best thing is to thaw out the coils and see if it happens again. You can test heater and timer with multi-meter to see if you are getting any reading
Posted on Jun 30, 2009
I have an Amana A4TXNWFWW01 and at the top part of the fridge there is two vents. These vent freeze over and the fridge quits working. Does anyone know what is going on?
The defrost heater has a defrost limit thermostat ( a small disc with two wires) that is attached to the cooling coil. This defrost limit thermostat is a switch that will open when the coil is warm enough after defrost. If the defrost heater is staying on too long it can create steam which will condense and freeze on the vents after defrost period terminates.
Jul 14, 2014 | Amana A4TXNWFWW Top Freezer Refrigerator
Evaporator coils icing up
The only possible source of water to freeze on the coils in such a short time is from the outside atmosphere. Check the door seals.
Oct 25, 2007 | Amana ABB1927DE Bottom Freezer...
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Runs all the time freezing ok fridge at max cool but not cold defrost element replaced 12 months ago
well, it sounds like its froze up again...pull panel and check coil..if froze up, defrost and check heater and timer and defrost thermostat
Jan 11, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer is partially freezing
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
