Question about Magellan Maestro 4000 Handheld GPS Receiver
The jack of the Magellan cigarette lighter power cable no longer fits tightly into the GPS and so is not making good contact and will not charge the unit. it seems like a part of the charger jack receptacle on the GPS has broken. There is a rattling noise when I shake the GPS. I'm trying to take the GPS apart to see if I can find the broken piece, but can't get the GPS apart.
    Brigadier General:
  • 4,090 Answers
They are difficult to open and not for the faint hearted, You could end up doing more danmage than you need to experience, plus losing some small bits. If you have damaged the charge circuit it will be expensive to repair as it is all on the Main Board
Posted on Jun 30, 2009
Magellan RoadMate 3000T. When plugged into the cigarette lighter, I only get a little red light in the upper right corner. How do I turn it on? I can't understand their symbols. (it is a hand me down from...
Download the manual from here.
The LED in the upper right corner seems to be a charging indicator, so this means that the power supply via the cigarette lighter seems to be ok.
To switch it on, press and hold the power button for 3 or 10 seconds (depends on the state of the device - whether in sleep mode or off).
Mar 11, 2010 | Magellan RoadMate 3000T GPS Receiver
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
Is rhe autupower cable all you need to operate the gps?
Hello, yes an external antenna is no longer needed with recent improvement to portable GPS systems.
You will need to place the GPS where it has a relatively unobstructed view of the sky.
I use a vent mount which are available for about $12. It clips into the vent louvers and positions the unit directly to the right of my steering wheel.
Please note it may take as much as 5 minutes for the GPS to obtain its initial position so be patient.
Also it may be a good idea to charge your unit, if it did not come with a 110v plug in transformer you can use a USB cable off your computer directly into the USB jack that provides power from your cigarette lighter.
Magellan often releases new firmware for their models so make sure you check their website, register your unit and download any updates that are available.
Hope that helps
Jan 03, 2010 | Magellan Maestro 3250 GPS
After recently purchasing my Magellan Roadmate 1400 GPS the cigarette lighter adapter cord no longer charges the unit. I am able to charge it from a regular AC wall socket but it will not start up in my...
look in the tip of the DC charger and see if the fuse has blown. This is usually the case.
Be warned! starting the car with the GPS plugged into DC can blow your SIIRF chip... no more satellites! and an expensive repair. be thankful it was the fuse this time
Jul 06, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Part of cigarette lighter connection stuck
Use a clean ice-cream stick and super glue and pull it out.
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Garmin Nuvi 300 does not switch on. The wrong charger was used
1. If using the power/data cable to power your device:
  1. Make sure you have power at the source it is connected to.
  2. Check the fuse in the power cable.
  3. Use a volt meter to test the end which plugs into your device (the manual for the device should show which pins are power and ground. Make sure you are getting at least 12 volts of power. This will ensure you are getting full power through the cable and determine if the cable is faulty.
2. If using a 12 volt cigarette lighter adapter:
  1. Check the fuse in the adapter.
  2. Make sure the cigarette lighter in the vehicle has power by connecting another device with a different 12 volt adapter if possible.
  3. Make sure the metal tip on your 12 volt adapter is still connected
3. If using batteries:
  1. Make sure none of the battery terminals are still connected to the device.
  2. Try new batteries.
  3. Make sure the batteries fit tightly inside the device. This will ensure the battery terminals are not loose and you have good contact.
4. If you are powering the device on the built in lithium ion battery:
  1. If you have a power cable for the device, plug it into a power source and see if the device will power on with direct power. If it powers on, check to see if the battery is fully charged.
  2. If it is not, let the battery fully charge and then try to power it on with just the battery.
Sep 26, 2008 | Garmin GPS
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
No power to unit, but powers on okay in house with AC power adapter
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Nov 12, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan Maestro 4000 Handheld GPS Receiver Logo
259 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
