Question about Toshiba Satellite A215-S4747 Notebook
Built-in Mic not working on laptop
I have a Toshiba Sattellite A215-S4757. Along with Skype already installed, it came with a built-in webcam and mic (also shown on a Skype sticker on the laptop). The microphone worked perfectly for the first few months before it suddenly stopped. After following the advice of Skype and several online forums, the mic can now only pick up the sound being projected out of the laptop (e.g. iTunes Library), but it doesn't pick up any external sounds. If there's any advice that can be given it would be greatly appreciated. Thank you.
My built in microphone is not working with Skype on my laptop Toshiba A215 s4767. I have gone thru and checked drivers and checked settings and it says everything is working fine. When I do plug in a mic...
1. Open "Skype".
2. Click on "Tools" tab.
3. Click on "Options" from drop down menu.
4. Click General Settings.
5. Click Audio Settings.
6. Select the correct microphone from drop down menu next to "Microphone".
7. hope it helps .
8. mark as solution. thanks.
Aug 15, 2013 | Toshiba Satellite A215-S4767 Notebook
What do you do if the built in microphone for the Toshiba Satellite M305D-S4840 is not working (not picking up sound)?
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
May 20, 2012 | Toshiba Satellite M305D Notebook
Does acer aspire 5532 have built in mic because friends can't hear me at all when on the skype network
In skype go to settings then the mic symbol you will see a dropdown box, make sure the webcam mic is selected and not the soundcard in your laptop
Jul 11, 2010 | Acer Aspire One PC Notebook
I have a toshiba l305-S5957 and can't find an internal mic for use with skype
While most laptops comes with a built in webcam and microphone, this particular model does not. If you don't see a web cam built in to the top of your screen, chances are you also won't find an internal microphone. You'll need to purchase additional accessories in order to use your laptop with Skype.
Mar 08, 2010 | Toshiba (P000257700) Microphone
How do I use the built in microphone in my Toshiba satellite laptop to make calls on Skype? At the moment I have to plug in an external mic and I'd prefer not to do that. Is that possible? Thanks!
of course it is possible,go to official site(toshiba),select Support & Downloads then select your laptop type,O.S. and webcam driver then download ,instal and then you can test it ,then configure skype to microphone.
Jan 09, 2010 | Toshiba Satellite Pro L300 Notebook
My built in mic (Toshiba L500-1GE) is not working properly (I can't use skype because people can barely hear me even when I'm speaking very loudly); tried to change sound (recording) settings and played...
I have a TOSHIBA L500 with WIN7-64
I have a problem with my mic, it started making this high freqency noise (when you put a mic close to speakers), so I had to turn the mic off in the control panel. Now I cant use the built in mic because it seems that it somehow deleted the driver. Can somebody help me with this.. I need to instal the built in mic for toshiba L500
Jan 05, 2010 | Computers & Internet
I am new to Skype and have registered . I have a Webcam - Microsoft Life Cam VX-3000- and cannot get any sound , using the test facility . Any ideas ? Everything else seems to be working and I have checked...
If you have a laptop it will have a built-in Mic
If you have a webcam with a built in Mic you now have 2 on your computer and you are going to have to determine which one to use (make it 'default')
I would recommend using the webcam mic as default.
You do not say what your pc or OS is so here is the setup for
Laptop x Vista
Set up Audio
Laptop x webcam/mic x Vista
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to Skype
If you have an earlier OS than Vista you may have to access your hardware from the Control Panel
Oct 02, 2009 | Microsoft LifeCam VX-3000 Web Camera
Toshiba Satellite A215-S4747 Notebook Logo
623 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
