Question about Microsoft Xbox 360 Console
Over heat 2 ring flah red - Microsoft Xbox 360 Console
  • 90 Answers
Dust! and or fan problems. I had to fix one with this same problem and found that only one of the two fans where working so I replaced the fan and it has been working fine. Oh and there was alot of dust all over everything.
Posted on Jul 03, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox360 showing 4 red lights then 2 red lights when I turn it on.
yes is call the ring of death . but you need to take your xbox to some where to repair it . take it to gamestop......search it in youtube ring of death
Dec 24, 2009 | Microsoft Xbox 360 Console
The bottom right red light is on when i turn my xbox on, what does this mean?
it is similar to the red ring of death on the 360 and it means that it overheated and damaged itself
Nov 23, 2009 | Microsoft Xbox Console
Xbox 360 immediately goes to 2 red rings (on start-up)
Temp sensor might be bad or there might be a short between the board and the sensor.
Oct 04, 2009 | Microsoft Xbox 360 Console
I have 2 rings problem
You've already deduced that 2 red rings means overheating. Here is a list of what to do to make sure there is no external reason for the overheat. It's all pretty obvious stuff but it sometimes helps to go through it methodically (My friend had his sat on the carpet - he got 2 red rings after about 3 hours)
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
  • As it happens my X360 has been sat on top of my Amp for 2 years although I rarely have it switched on :P
    Jul 21, 2009 | Microsoft Video Game Consoles & Games
    2 red ring
    try keeping your xbox wrapped in towels
    Mar 29, 2009 | Microsoft Xbox 360 Console
    2 Red rings
    Do the x-clamp fix again making sure the chip is very clean. Then make sure when you set the heat sinks that they are perfectly flush on the chip but don't tighten them real tight about 3 inch lbs is plenty. Leave the "towel trick" for the drunken monkeys out there. If you havn't fried it google "Air Flow Box" or find it on ebay this will help air flow under your MB was well as air flow over the heatsinks. It will also make cleaning the heatsink easier with out cracking the box. The 360 has a very anemic cooling system you have to fight heat aggressively. The stock 360 gets so hot it can loosen the solder joints I guess so you have to do everything you can. I put the Air Flow Box in a new console with the Falcon board along with the extra heatsink on the video scalar chip. Why run something that is designed to overheat. A 40%failure rate is attributeable to poor design in cooling IMHO. Don't let me tell you haow to act but you have to fight overheating from the getgo.
    Mar 22, 2009 | Microsoft Xbox 360 Console
    2 Red Lights Xbox 360
    You need to change the thermal compound.But if you have make sure you have 1 WASHER ABOVE THE MOTHERBOARD! 2 washers above are too many. try that and let me know how you got on
    I had this exact issue 2 washers make the heatsink sit off the GPU Die. 1 allows it to touch the GPU DIE
    Feb 12, 2009 | Microsoft Xbox 360 Console
    Two red rings
    The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
    Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
    To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
    There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
    Jul 18, 2008 | Microsoft Xbox 360 Console
    I have 1 red light on my xbox 360
    ok one red light means a fault be warned this is also called the 3 rings of death if u get 2 flashes or rings it will over heat or freeze ,and if u have 3 xbox is dead ,
    one means fault is it over heating,in a confined space ,
    here is a site so u can see whats goin on with your xbox
    http://editorials.teamxbox.com/xbox/1651/The-Red-Ring-of-Death/p1/
    Jul 04, 2008 | Video Game Consoles & Games
    Microsoft Xbox 360 Console Logo
    Top Microsoft Video Game Consoles & Games Experts
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
