Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Why does unit leak on ac in room - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
    Scholar:
  • 70 Answers
Drain maybe plugged or real high humidiy in room could cause this. Check drain for plugs and traps. **** out with shop vac or blow out. flush drain with bleach water.
Posted on Jun 30, 2009
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
Not cooling 110 sq ft room
The smallest retail AC unit will cool down a 110 sqft room if...
1. It is installed in a way as to dump heat outside... 2. There is actually cool air coming out of the AC (it is working)... 3. The windows and doors are tightly closed... 4. There are no major drafty leak issues (i.e. hole in a wall)... 5. You're not adding substantial heat energy into the room (such as having 10 sweaty fat men eating food while watching Super Bowl on a 56" LCD TV)... 6. The room has at least minimum insulation (the walls are not just plywood)... Seriously, if HEAT is leaving the room by way of the AC, the room temperature HAS to decrease, unless HEAT is being added back into the room in some way. This is basically the 1st law of thermodynamics.
Jul 24, 2011 | Heating & Cooling
Brand new GE room size ac unit (1 week old) is spiiting water out of the air vent into the room. Unit 100% level.
If a brand new unit is spitting water, i waould suggest that it is short of refrigerant... Get your installer back or the Manufacturer.. You need to hold An ARC licence to do this ( In Australia)
Jul 16, 2011 | Heating & Cooling
My LG Split AC leaks, the water drips from the front right side (inside the room, where it is installed) instead of from the drainage pipe (outside the room). What to do?
Hello, make sure the unit is tilted back somewhat so the Condensate can drain toward the back and not collect up in the front. Also, make sure the drain tube is not obstructed or blocked with sludge.
May 25, 2011 | LG Heating & Cooling
Haier ac unit keeps freezing in the front where the filter i located how do i prevent this
Freezing is a bad sign... but dont give up yet...
these are the signs that will cause freeze up...
dirty filter
t'sat not shuting off
cooling a room too big for the unit
settings at max but room is still hot
and the worst case... a/c leaking freon..
the leaking part is bad cause if you get someone to put it back in next year (or sooner) you have to call em back to recharge it again...
if everything checks out then it is the leaking freon... throw away...
what you pay $100 or so???
hope this was helpful
Apr 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
Leaking into room
the drain may be clogged or clean filter/coils
Aug 11, 2009 | Heating & Cooling
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Jul 28, 2009 | Amana Comfort Zone 12M32PBEH Air...
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
408 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
