How do I switch the bluetooth on on my U90?
It didn't come with a user guide, and the msi website's suggestion of 'press the wireless button once for wan, twice for bluetooth, three times for wan and bluetooth' switches the wireless on, off, and on! SERIOUSLY confused here! I can't find an option to enable bluetooth anywhere! HELP!!!
  • kate8277 Nov 27, 2009
    Thanks for your help guys, but unfortunately I have since discovered my inability to read. The reason why Fn+F11 switches only wireless on-off-on-off with no sign of bluetooth activity is, in fact, because bluetooth doesn't exist on my model. I knew the Fn+F11 trick, but as I say, it only worked on the wireless side.
    From now on, I intend to actually read the box!!! :-D
I tried that but it cant catch any from mobile bleutooth..
Posted on Jul 05, 2010
  • 72 Answers
U90 - FN+F11, Multi-press switch, Green LED - Wireless is on, Blue LED - Blue Tooth is on, Green & Blue LED, both are on
Posted on Nov 27, 2009
  • 3 Answers
Fn + F11 toggles the wireless, bluetooth, and then both options
I found a manual online, but I can't seem to findthe link right now.
Posted on Sep 07, 2009
  • 197 Answers
It should have a button on your machine. locate it on the side and switch it on.
Posted on Jul 01, 2009
How do i get bluetooth to work on my msi U135DX?
Run windows update to check if you have the latest drivers.
Feb 28, 2011 | Computers & Internet
How do i switch on wireless on msi u90 notebook
Hello, You can put on your wireless on your MSI U90 notebook by pressing on the fn key and function key (F11). I hope this solution is helpful. Have a wonderful day.
Oct 10, 2010 | Computers & Internet
I cannot get the bluetooth in pairing mode
Each Bluetooth headset is different when it comes to this, you'll have to check your user guide for the correct combination and timing of buttons. If you don't know where your user guide is, (shame shame!), then try some of the more common ways to get into pairing mode. Hold down the main button until the light flashes rapidly (3 seconds or less between flashes). If that doesn't work, try pressing and holding the main button and the +Volume button at the same time until the light flashes.
Sep 29, 2010 | Just Wireless Bluetooth Headset Wireless...
Hi i have a u135 and it hasbuilt in blue tooth but i donot know how to activate could u help
Not sure if this will work for your model but its worth a try. Copied from MSI support faq website
You have to press the WLAN button located right next to the power button in order to enable/disable the Bluetooth function. Press WLAN button once, Enable WLAN. Press WLAN button twice, Enable Bluetooth. Press WLAN button thrice, Enable both WLAN and Bluetooth. Press WLAN button four times, Disable both WLAN and Bluetooth.
Aug 26, 2010 | MSI U100-422CA Notebook
Webcam on using msi wind u90 notebook
It sounds like you need to reinstall the software driver for your webcam to match your new OS version. Try going to the manufacturer's website Support section to see if they have driver downloads. If not call them up. If you provide the model of your laptop I'll help look it up.
May 11, 2010 | GE EasyCam Webcam
Cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Apr 01, 2010 | MSI Wind U100-030US Laptop
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
How do u turn off the bluetooth on the msi wind netbook
Press【Fn 】+ 【F11】for Bluetooth \ WLan functions
I believe that the number of times you press the FN+F11 button, these would be the results. I hope this helps you.
1. Both Bluetooth, Wireless LAN Off
2. Bluetooth Off, Wireless LAN On
3. Bluetooth On, Wireless LAN Off
4. Both Bluetooth, Wireless LAN On
Oct 20, 2009 | MSI Wind U100-004US Notebook
Using bluetooth on msi u90 HELP PLSE
U90/U100 - FN+F11, Multi-press switch, Green LED - Wireless is on, Blue LED - Blue Tooth is on, Green & Blue LED, both are on.
Aug 09, 2009 | Computers & Internet
Can't get it to connect to wireless
From User manual you can download from HERE:
1) activate your WLAN :
repeatedly to enable or disable the Wireless LAN or Bluetooth function recurrently.
2) Check if "Wireless LAN LED indicator glows green when Wireless LAN function is enabled."
3 ) Use Windows to configure your Wlan.
Let me know if you need more help.
Dec 29, 2008 | MSI Wind UmNotebook
Computers & Internet Logo
482 people viewed this question
David Payne
David Payne
