Question about GPS
My blue tooth is paired with 1 blackberry and I need to pair it with a different one and it is not working or recognizing the new one
    Brigadier General:
  • 4,090 Answers
Your new one may be a type 2 and your old one a type one. It is not upwardly compatible. Does your new one see the older unit?
This would confirm that the older unit can be read by type 2 but not the other way round
Posted on Jun 30, 2009
IHF1000 IS NOT PAIRING SUCCESSFULLY WITH MY VERIZON BLACKBERRY PHONE. I ENTER THE CODE 1-2-3-4 REQUESTED, NOTHING HAPPENS, SO THEN I REPEAT PAIRING STEPS?
yes most motorola blue tooth devices have a pin pairing code of 0000 andyou have to make sure your blue tooth device is in discovery mode.
Feb 25, 2011 | Motorola Radio Communications
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
I am trying to pair the jwin JB-TH130 with a MyTouch 4G cell phone and the phone will not recognize the bluetooth device.
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
Feb 19, 2011 | Jwin JBTH130 Bluetooth Headset
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
I need need pas key for plantronic 220 pairing to a blackberry 8300. jguyden@ccny.cuny.edu
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Sep 14, 2010 | Cell Phones
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
Have a nice day.
Sep 01, 2010 | Cell Phones
How to connect by bluethooth in Lexus 350 to blackberry 8520
Take care.
Aug 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
What is the passkey to my sony vaio laptop VGN-CS160J
If you have a blue tooth device added to your laptop or build into your laptop, you will have to enter control panel and select Classic View at top left and then select Blue Tooth.
Once you are in that option window you should go to security and set your passkey there and then. When you apply your settings and return to Pair your devices you only need to use the passkey that you have entered at your blue tooth security and you should be all sweet.
Aug 23, 2009 | Sony VAIO VGP-BMS33/B
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
