Question about GE WHRE5260E Top Load Washer
WILL NOT STOP FILLING
WASHER CONTINUES TO FILL. WILL EMPTY ON SPIN CYCLE
  • 97 Answers
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Posted on Jun 30, 2009
  • MrQuickFixit Jun 30, 2009
    Also, forgot to tell you another possible problem. The pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
I have the same problem but with mine the weater continues to run out the drain hose. The pump is not on but I found out my waste line is to low so it gravity dumps. i had to get a longer hose so that I could raise it high enough to stop the problem .
Posted on Aug 21, 2009
LG front load washer continues to fill with water after spin cycle
Bad water valve or main board. the water valve closes when it stops receiving voltage from main board. If it's not closing then valve is bad.
Apr 07, 2014 | LG Washing Machines
Won't stop filling. When I go through the cycles it continues to fill until I reach the final spin cycle then it will start draining and spin out.
Two common problems for this simptom:
If water stops filling when you disconnect the washer:
Change the pressure switch.
If water keeps coming in after you disconnect the washer:
Change the water valve.
GOOD LUCK MY FRIEND
Aug 30, 2009 | GE Washing Machines
My washer fills VERY slowly and will not stop filling after cycle
It sounds like the water inlet valve is stuck partially open and needs to be replaced. It's located on the back of the machine where the hoses attach.
Jun 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
GE WHRE5260E Top Load Washer Logo
290 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
