Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
Ridgid 16.5 gallon motor running with no suction
I ran my Ridgid to **** up dry dirt and construction leftovers, then used it when my basement flooded. It worked fine, until the water backed out of the nozzle and leaked out of the back hose hole. I tried to use it again and it started up, then quickly lost all suction and water came out of the hose. I cleaned the filter (yes, it was filthy) and still nothing. Have I damaged the unit beyond repair. I noticed that the filter is torn, so is it just a filter issue?
  • 41 Answers
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Posted on Jan 05, 2010
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
Should I remove the filter when using it as a wet vac. I t does not seem to have much suction.
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
Jul 08, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I need a manual for ridgid wet/dry vacs model #wd16500
I was unable to find the model WD16500 instruction manual anywhere online. In fact I did even find a link to that products owners manual, but when I clicked through the page no longer exists on Ridgid's site. I was able to find the parts diagram for the WD16500, and the instruction manual for the WD16600 which is also a 16 Gallon Detach Wet/Dry Vac, also with a detachable blower, and the model that even replaced the WD16500.
I also left you the number to Ridgid if you'd like to contact them, they may be able to mail you a paper copy of the instruction booklet.
I hope this helps you:
Instruction Manual:
http://www.ridgidparts.com/pdf/WD16600.pdf
Parts Diagram:
http://www.ridgidparts.com/cgi-bin/etcTable?showTable=1&table=WD16500-Figure1&image=Vac
Phone Number for the Ridgid Company:
1-800-4-RIDGID
If this was helpful, please be so kind to rate my answer as helpful, this is what keeps me coming back to Fixya to help people with their vacuum related questions. Thanks alot, I really do appreciate it.
Chris J.
GoVacuum
Apr 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
891 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
