Question about Ricoh Aficio 250 Copier
Sharp ARm160 bypass problem
The copier is not moving the paper in it clicks but the roller doesnt move
so i want to replace the bypass and i dont have a service manual to do it any one help thanks
  • 257 Answers
Try to clean the roller before you replace the bypass tray
Posted on Jul 01, 2009
How do i locate the polygon motor for sharp arm160
Hello ARAM,
The operation manual can be viewed here: http://www.gfive.net/pdf/manuals/AR-M160-Manual.pdf
The part you requested can be ordered here; Sharp ARM160 Polygon Mirror Motor Genuine J0349
Good Luck!
Rich Lilja
Mar 04, 2015 | Sharp Office Equipment & Supplies
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
Hello I need help with a Sharp AL-1631 copier
are you talking about the bypass paper source?...if yes then the clutch lever support on your bypass assembly is probably broken, try to feed using tray 1. if it is ok...
Apr 28, 2010 | Sharp AL 1631 Copier
Power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 10, 2010 | Minolta EP1030/1030F CS/PRO Copier
Paper pickup
Does it move the paper at all? If you have more than 2 drawers do other drawers work? Does bypass tray work for feeding paper? If paper does move does it always stop at same place?
Jul 03, 2009 | Canon Office Equipment & Supplies
Print to bypass
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
May 19, 2009 | Sharp MX-2700N Color Copier
Printer
u have need to change gire box of printer due to long time use its needs to chnge it thats y its will happen or also try to clean the roller due to dusting problem might be roller cant pikup paper
Jan 11, 2009 | Lexmark Office Equipment & Supplies
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Ricoh Aficio 250 Copier Logo
63 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
