Question about Oreck XL Ultra Bagged Upright Vacuum
Installing roller brush for oreck XL 21 - Oreck XL Ultra Bagged Upright Vacuum
    Sergeant:
  • 206 Answers
Uh, probably not sure what the issue is, but
1. unplug unit.
2. Remove the multiple screws from the bottom of the unit.
3. remove the bottom baseplate (usually black)
4. the brush roll is now visible, and the belt should be around it.
5. Pull the brush roll away from the unit, and disengage the belt.
6. Replace in the opposite order. Make sure that baseplate fits properly to insure a good seal. Also watch the bumper (rubber part that is wrapped around the unit) to make sure it is properly seated.
7. Handroll the roller brush before plugging in. Make sure it moves freely.
8. Run unit, may get a slight burning smell, but if this continues for more than a minute - turn off and inspect the unit. Brush roll requires a short burn in time, on initial build, factory accomplishes this during test procedures.
Posted on Jul 30, 2009
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
http://www.oreck.com/oreck-xl-classic-limited-edition-bagged-vacuum/UK2200.html
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Returns
Oct 30, 2016 | Oreck Vacuums
Hi do you carry the roller brush parts for this model?
Hi Rochelle,
This is Leland with Crucial Vacuum,
We carry the roller brush, and some other products for the Oreck XL, which you may find in the link below:
http://www.crucialvacuum.com/catalogsearch/result/?q=oreck+xl
You can purchase replacement parts for your Oreck unit direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendlycustomercare representatives on the line ready to assist you.
Jan 29, 2016 | Oreck XL Power Team Upright Vacuum -...
I changed the roller brush on my Oreck XL Insight vacuum and now when I turn it on it only runs for about 5 seconds and shuts down Any ideas
Bigme03,
It sounds like you may have been given the wrong brush roller. Several models of Oreck's have a sensor in them that watches for the brush roller turning at the proper speed. The way they do this is by mounting a magnet into the brush roller and the sensor counts the number of times the magnet passes. If that magnet is not there or if the sensor does not detect the magnet passing, ie..a broken belt, it will shut the motor off. The only way you can fix it is to get the correct brush roller and put it back in. Hope this helps!
Mar 07, 2015 | Oreck XL Insight Upright Vacuum
Which way do the ridges go on the brush roller of an Oreck XL
If you are talking about the ridges on the bearing blocks at each end, here is how they go. If it is a new brush or less than a year old, the side with multiple ridges will face up as you put the brush roller into the machine. If the roller is no longer pulling against the carpet or it is more than a year old, turn both bearing blocks to the side with only one notch showing. That will lower your brush closer to the floor and let it pull against the carpet. If you have it in the lower position and it does not pull, you may need to consider replacing the brush. Hope this helps.
Sep 01, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck brush only turns a tiny bit and belt pulley get hot belt not turning much either
If your brush is not turning properly then you need to check the bearing ends to see if there is any hair, string, or thread wound around the brush shaft. If there is and you can remove it, that might fix your problem otherwise I would suggest getting a new brush roller.
Jun 30, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Why is my oreck xl 21 hard to push on carpet?
sometimes the little rubber wheels in front wear out of round and bind. Try those first (if they're the tiny ones you must buy a pack of 20 from oreck directly) and Orecks are known for being hard to push when bag begins to fill up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
May 03, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My oreck will not pick up dirt from my carpet I cleaned the roller brushes well but there is a tiny bit of dust blowing out of the unit from the bottom
The nozzle behind the roller brush is probably clogged. Take a screwdriver and stick it in there and work it around and see if it loosens the clog.
Aug 25, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Commercial XL 21
Check that the beater bar is completely clear of thread, this will bring the brush roll back to normal. Also check the sides of the brush roll doesn't have anything such as thread or thick string at the sides.
Jun 16, 2009 | Oreck XL21 Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
606 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
