Question about Emerson Pool & Spa
Pump work for about 10 minutes and then stop - Emerson Pool & Spa
    Scholar:
  • 34 Answers
Three things kill a pump, air, electric or dirty filter
1. Make sure that you are not using an extension cord.
2. If you can see water swirling around in the basket on the front of the pump you have air working it's way in.
3. If not 1 or 2 do you have a DE or Cartridge filter. is so might need an acid bath.
If you see water swishing around in the basket you are taking in air which will work to kill the prime on a pump. Check the water intake connection on the front of the pump and the strainer lid for worn out o rings. An o ring that is cracked or leaves black reisdue on your finger needs to be replaced. Never use vasoline to lube orings.
If you want to check this insert a garden hose while the filter is off into the jet that puts water into the pool. By doing this "reverse prime" you can find the suction side (any connection before the pump) that is loose. Since they wont leek under normal operating conditions this will help flag any bad oring or connection.
Posted on Jul 03, 2009
Stop after 5 minute
Is the pump underwater? I would guess this is a sewage pump since it is a 2" discharge. If it is not underwater it will get hot and trip thermal overload. Why is it running for 5 minutes? That is a lot of water to move assuming your not trying to lift it over 10".
Apr 02, 2014 | Liberty Pumps LE41A 4/10 HP Auto...
I have a 1989 dodge dynasty that kills for no reason then after 5-10 minutes it starts and runs fine?
maybe its overheating. if not id say falty fuel pump. it gets hot and stops pumping. check alternator.
Mar 11, 2013 | Cars & Trucks
I have a polaris pump. It starts and runs good cold. After about 30 minutes of use it stops for maybe 10 minutes and starts for about 10 -30 seconds. I usually stop it for about 1 hour or more and then...
THE LITTLE CAP ON THE TOP OF THE MOTOR IS THE RUN CAPACITOR, TAKE IT OFF AND HAVE IT TESTED. BE CAREFUL THESE CAN HOLD VOLTAGE AND GIVE A NASTY SHOCK ! SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING..JAY
May 31, 2011 | Polaris Pb4 - 60 Booster Pump
Onan generator dies after 2-3 hours of running , wiil not restart rigt away wait 10 minutes starts no problem then runs for 15 minutes shuts down and keeps reapeating on 15 off 10
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
First 10 minutes it is working fine. After 10 mins it is getting stopped and started automatically for every 2-3 seconds.
sir i'm sorry to say you have air in your system. the trouble is at the orfis,seperating high side to low side. water molecul freezes then melts. very comon in ref. system. either pump down the system or isolate ga and add a filter dryer for that size unit
May 03, 2009 | Heating & Cooling
Pool & Spa Logo
183 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
