Question about Samsung HT-WX70 Theater System
Samsung ht-wx70 shutting off for protection
The unit started to shut off by itself and a protection warning came on> I open the unit and noticed that the coil near the fan was very hot, I will try keeping the unit unplug !! I will post the outcome
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Posted on Jul 03, 2009
Fan check blinks on the display and then shuts the system off?
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Resolve this issue and it will probably stop trying to protect itself by shutting off.
Feb 14, 2010 | Samsung HT-WX70 Theater System
Samsun HT-WX70 overheating and shutting down
The receiver in the Samsung ht-wx70 system that I have runs fine until all of a sudden I hear a loud bang and it shuts off. If I touch the unit, it is burning hot. I took the fan out and it works when I attached it to a 9v battery. Is it the fan or another problem that I should be looking at.
Oct 04, 2009 | Samsung HT-WX70 Theater System
Powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Jun 30, 2009 | Samsung Audio Players & Recorders
Hello Protection Samsung HT-DS900
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 14, 2009 | Samsung HT-DS400 System
HOW DO YOU RESET A SAMSUNG HT-WX70 HOME THEATRE SYSTEM?
According to the instruction manual you turn off the unit and press the Stop button on main unit for at least 5 seconds. Didn't help me with my problem (shutting down for no apparent reason) maybe it will help you with your problem.
May 06, 2009 | Samsung HT-WX70 Theater System
SYSTEM SHUTTING OFF
Sure for helping,
If there is a power problem means it will not turn on man,
so kindly check with the power cable, there might be problem with the power cable thats why it is switch on and there after it switch off,
so to resolve your issue you please change the power cable and if you find still problem you please contact once again i will give you the final solution for that ok.
Mar 26, 2009 | Samsung HT-WX70 Theater System
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Unit shuts itself off after 10 -15 minutes
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Surround sound shuts off like the sleep timer is on
power amp problem are you familier with electronics?
then we can do more.
shall we?????
Jan 03, 2009 | Samsung HT-WX70 Theater System
System turns off by itself
My unit said "protection", "goodbye" so I opened it up and found a capacitor to one of the speakers had blown, right by the fan. It's a 35 cent part and a simple solder job. The hardest part was getting the face plate off the dvd tray so I could get to the circuit board.
Apr 01, 2008 | Samsung HT-WX70 Theater System
Samsung HT-WX70 Theater System Logo
902 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
