Question about Whirlpool ED5FTGX Side by Side Refrigerator
How do I get the water dispenser on the outside of the door to quit dripping water
  • 4,070 Answers
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
Posted on Jun 30, 2009
How to fix water leak on GE Profile Refrigerator
I would look at the dispenser door for the ice (ice chute) I have seen this door not completely close and cause leaking the you are describing. This door is has a black seal, use a flashlight, from the inside of the freezer door, look for light on the outside of the door. I think you leak is there and replace the solenoid for the door to fix this issue. Good Luck, if you want more help please input a model number. Thanks
Aug 17, 2014 | Refrigerators
Leaking water dispenser
Bernie,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispensor is ALL the way closed.
Oct 12, 2013 | Sub-Zero 661/F Side by Side Refrigerator
Maytag MSD2272VEB00 leaking water
Laura,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispenser is ALL the way closed.
Oct 12, 2013 | Maytag Refrigerators
Door dispenser drips
I am assuming when you say the door dispenser drips, that you mean the water dispenser. I had the same problem with my Samsung fridge Freezer, it just turned out to be that the water pressure from the tap supplying the dispenser was turned up too high, the advice I was given (from an engineer) was to turn down the pressure a little then run the dispenser for approx half a litre, then let it sit for a while to see if the drip continues, if it does, try again, it took a few adjustments but we're running fine now, but don't forget, it's normal for a dispenser to drip once or twice after its use. Good luck.
Jun 17, 2012 | Samsung RF265AA Bottom Freezer French Door...
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
WATER DRIPPING IN DISPENSER TRAY DUE TO ICE MELTING AT FRONT OF DISPENSER
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Whirlpool ED5FTGX Side by Side Refrigerator Logo
207 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
