C-50 code on a Minolta EP3130F?
  • Office Equip... Master
  • 6,696 Answers
THE C500 code is default fusing unit. EP3130 is a legacy machine, mite try reset button in side of the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 13, 2009
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
I need help to clear error 18 on konical minolta 240f.
Code
18
Description
Fuser Error
Remedy
Nov 19, 2017 | Minolta Office Equipment & Supplies
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
My dialta minolta di183 is showing C06 50 code and i dont know how to go about it
Clean the home scanner sensor scanner is what moves as it scans the document. then go back to home position there is sensor that tell the copier it is back home clean dirt or might need to be replaced.
MINOLTA CODE PANNE C 0 D 50
Duplex unit problem,pull out /push in the duplex unit.Open close the front cover.
Jan 15, 2013 | Konica Minolta Minolta Ep4000/ep5000...
Give me minolta sp4000 code 0 d 50
The C0d50 code Duplex unit drive motor failure to turn.Turn ON the copier,open and close the front cover,pull out the duplex tray,clean the rollers alignement the belt.
Enter in the service mode press : STOP - 0 - STOP - 1,select F code history open and close the front cover,press Exit,Exit.
Jan 04, 2013 | Minolta Office Equipment & Supplies
C 50
There is no C50 code on this machine. All Minolta fault codes on the 4000/5000 series machines are a letter followed by 4 numbers. So the code would be like C0050 or more likely C0500. Let us know the actual code so we can be of assistance.
Thank You
Sep 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error Message C 50 on a Minolta 1031F copier
Fuser code, to reset turn of the machine, if it comes back on the fusing unit the (Hot part) needs to be replaced Upper fuser roller (UFR) carries the lamp. Check the thermistor and thermostat also before replacing UFR
Jul 28, 2009 | Minolta Office Equipment & Supplies
WE HAVE A MINOLTA EP1030
I really needed my copier so I took it down to the service center this morning. They are suppose to call me with an estimate. He said there are three or four different reasons the machine would show a code C-50 and he needed to look at it before he could find the problem. Thanks anyway
Dec 29, 2008 | Minolta EP1030/1030F CS/PRO Copier
50 people viewed this question
k24674
jasbo
jasbo
