Question about Frigidaire FSC23F7D Side by Side Refrigerator
Moved our fridge, cleaned it and plugged it in. now when the compressor starts it trips the GFI
Ice maker wont produce ice and water disp has a couple drops water then stops everything else works gret
Posted on Jul 28, 2009
  • 4,070 Answers
Try it without a GFI. I don't think they work well with them.
Posted on Jun 30, 2009
Kenmore Side by Side 10658282891, it keeps tripping the gfi. We have tried replacing the gfi, the outlet, and cleaning out under the fridge. What could be causing this?
I this the only thing on that plug or is there other things that also go out it could be the motor is just pulling to many amps trying to start the compressor check the voltage its drawing at start up.
Oct 25, 2011 | Kenmore Side by Side Refrigerator
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I cleaned my Kenmore 59658692890 and moved it to the garage. When I plug the fridge in the GFI trips. Any suggestions?
Refrigerators has starting amps that do not done well with GFI circuits.
GFI is designed to trip with a power surge.
Refrigerators have power surges.
Find a non-GFI circuit to plug into.
Jun 27, 2010 | Kenmore Refrigerators
10 year old air compressor cuts off at 10psi
hello, if you plug the compressor into a none gfi outlet does the compressor still cut off ? it could be one a short in your compressor causing the gfi to trip our your gfi has a ground try the compressor in a diffrent outlet, when you use any other electronic equipment on the gfi does it still trip ? if you use the compressor in a diffrent outlet that's none gfi this should sholve your problem most likely a bad gfi outlet or the compressor is drawing to much amp's.
Mar 28, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Jan 24, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
Beverage air dd78 comp.wont start..tripping GFI
Refrigerators often will trip the gfi via the compressor. If you have checked all the wiring. The problem is likely in the compressor windings. I have had this occur in brand new units. Another thing to check the gfi, less expensive gfi outlets do not handle refrigeration equipment well. You should consider getting an industrial rated outlet. Hope this helps.
Oct 22, 2007 | Beverage-Air Beverage Air 2- Tap Unit...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
184 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
