Linksys Wireless-G WRT54GS Router
Problem for Linksys Wireless-G WRT54GS Router (e125894)
Hi I upgraded my blue ray player's firmware, and
By beej_william on Jun 30, 2009
Hi I upgraded my blue ray player's firmware, and after I did I can't get access to my Linksys ip address. When I type in the default 192.168.1.1, I get an error message from Explorer. Can sommone help please...
Best Solution
posted on Jul 07, 2009
Very Helpful)
redhaze89
Rank: Guru
Rating: 85%, 208 votes
Warning Enable dynamic content when you really want to use it. By default, IIS disables dynamic content for security reasons.
To permit IIS to serve dynamic content, the administrator must unlock this content in the Web service extensions node in IIS Manager. To do this, the administrator must either enable a pre-existing Web service extension or add a new Web service extension.
Enable a Pre-existing Web Service Extension in IIS 6.0
To permit IIS to serve content that requires a specific ISAPI or CGI extension that is already listed in the Web service extensions list, follow these steps:
  1. Open IIS Manager, expand the master server node (that is, the Servername node), and then select the Web service extensions node.
  2. In the right pane of IIS Manager, right-click the extension that you want to enable. In this example, this is Active Server Pages.
  3. Click to select the Allow check box.
Add a New Web Service Extension to IIS 6.0
To permit IIS to serve content that requires a specific ISAPI or CGI extension that is not already listed in the Web service extensions list, follow these steps:
  1. Open IIS Manager, expand the master server node, and then select the Web service extensions node.
  2. In the right pane of the IIS Manager, click Add a new Web service extension under Tasks.
  3. In the Extension name box, type a friendly name for the extension that you want to add (for example, FrontPage Server Extensions).
  4. In the Required files box, click Add, and then select the path and the name of the file that will handle requests for the specific extension. After you select the path and the file name, click OK.
  5. If the extension must be enabled immediately, click to select the Set extension status to allowed check box.
  6. Click OK to save your changes.
Additional steps for Common Gateway Interface (CGI) applications
For CGI applications, you must also follow these steps:
  1. Right-click Default Web Site or the Web site that you want, and then click Properties.
  2. On the Home Directory tab, click Scripts and Executables in the Execute Permissions list.
  3. Make sure that the Everyone group has the following NTFS file system permissions on the C:\InetPub\wwwroot folder or on the folder that has the Web content for the site that you want:
    • Read & Execute
    • List Folder Contents
    • Read
  4. Right-click Default Web Site or the Web site that you want, and then click Properties.
  5. On the Home Directory tab, make sure that DefaultAppPool is selecting in the Application pool box. If another application pool is selected, follow these steps in IIS Manager:
    1. Expand Application Pools, right-click the application pool that you want, and then click Properties.
    2. On the Identity tab, make sure that one of the following conditions is true:
      • The Network Service account is selected.
      • The account that is selected is a member of the IIS_WPG group.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Linksys Wireless-G WRT54GS
Questions and Unsolved Problems for Linksys Wireless-G WRT54GS
Do you recommend Linksys Wireless-G WRT54GS Router (e125894)?
Answer
Answer
where do i find my subnet mask ,router and dns numbers
Answer
THE settings on the computre dont match the requirments of the network
Answer
one works fine the other says cannot connect looking for windows certificate
Answer
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
