Question about Kitchen Appliances - Others
Vcr channels are starting at36 how do i get others -no remote
  • 11,896 Answers
You will have to purchase a universal remote to access the menu
Posted on Jun 30, 2009
I have a mitsubishi black dimond vcr id like to tune into a sharp tv how do i do this please
Ok, to hook it up to use as a Receiver, and TV, as a "Monitor". Using the antenna cable, plug this into the antenna IN socket on VCR. Now connect up, AV, using the Yellow, Video, Audio, is Red & White, on BOTH TV & Video. Now select an EXTERNAL INPUT on the TV. Now You Tune, and scan for "Channels" using the VCR. Find each channel, and save, now, you use the VCR remote to change channels, and the TV, is used as a "Display Monitor".
The Other way, is to just use the VCR as a "Recorder only, you plug the antenna, into the TV, now at rear of TV, you have a Video OUT, Yellow, and Stereo, Audio OUT, Red & White. Connect up the VCR to the TV using them. Now anything you View on TV, will be out put to the VCR, when you wish to record, simply press record, on Remote/VCR as desired. and it will record.
Apr 08, 2010 | Televison & Video
I can't get channels bwyond 13 and remote is gone so I can't reprogram for other channels. Can this be done withour the remote?
hopefully you have a menu button on your TV, if so you should be able to access auto program (you might have to search to find the auto search)but before you auto program make sure you set your TV to a cable setting then auto program. If you do not have a menu button on the TV, you could also try buying a universal remote. If you don't want to do that you could always use a VCR, just set your TV on channel 3 and do a auto program on the VCR ,using the VCR remote you should be able to tune in the channels your missing through the VCR.
Jul 07, 2009 | Televison & Video
No channel 4 on hitachi vcr, no remote
Ther should be a switch on the back of the VCR to swith between channel 3 and 4.. you can also cycle through the channels on the vcr there should be a channel button on the vcr
Mar 06, 2009 | Televison & Video
Problem with old TV
The channel is almost always 3 or 4. Be sure you have the VCR connections correct. Just hook up the TV and VCR alone to start with and try both the VCR and DVD. Also the output of the VCR should show a blue screen.
Dec 17, 2008 | Memorex MT1194 19" TV
Lost remote mrd 310
most universals will use this method.
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 29, 2008 | Philips Magnavox Learning Universal Remote
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
Mar 06, 2008 | Hitachi VT-RM380A Remote Control
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
No remote - need code, and can only get one channel
sorry bad link heres the right one search the page for a manual under product details 590kb pdf http://www.amazon.com/RCA-VR552-4-Head-VCR/dp/B00000J025
Apr 02, 2007 | RCA VR552 VHS VCR
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
