My PalmVx has lost its screen orientation so that I cannot get the system to respond to touching the screen. Even pressing the restart button on th eback only takes me back to the set up screen that I can't access becasue the screen isn;t working - any tips gratefully received!
The touch screen no longer works. I, too, have used the reset button but had no succes. Unit is fully charged, functions come up, but I cannot enter any data or get response from the screen.
Comments:
Nov 08, 2007
- Amazing!! It is just like new...I lost data but it doesn't matter...I haven't been able to use it for 4 years...so everything there was OLD and backed up elsewhere. Thanks so much!
-   is it possible to obtain a replacement touchscreen for the Nokia 770 tanet and is it an easy install, any advice welcome... pughder
-   pughder
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Vx.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Is there a way to make someones caller ID picture full screen size? Theses just a very small box...
(More)
Is there a way to make someones caller ID picture full screen size? Theses just a very small box that pops up now and I couldn't find anything in the manual.
i have a palm m130 im trying to connect to wind vista is there a driver that will work or software i...
(More)
i have a palm m130 im trying to connect to wind vista is there a driver that will work or software i can get
