Acer travelmate 4152lci laptop mouse pad not functioning since machine last shut down (with no apparent problems) - external mouse plugged in via usb port works fine, mouse pad settings show "enabled" and "device functioning" in properties - how can i make mouse pad function again, or is it likely to be a physical problem, eg loose connection etc
Tebebe Mengistu... wants more answers to this question
are you hyjacking now 2019 year?
if yes the answers is simple.
1: get the pad drivers from acer. we are not them.
2: if still fails for your unstated OS the pad is bad or its cable is bad. called bad hardware. we replace it.
Sometimes it’s dust, clean properly, or you replace it
Charm Sonic Welcome to Charm sonic
Try to re-intall your mouse pad driver and update your machine's bios.
if still doesn't work then you mouse is faulty and might need to replace.
