Question about Refrigerators
Motor running all the time and what should be the temp inside freezer and refig
    Sergeant:
    Champion:
  • 235 Answers
Freezer 10 degrees or less. fridge 33-40 degrees. Make sure there is good circulation inside and the coil is free of dirt and dust.
Posted on Jun 30, 2009
  • 40 Answers
If it has got a new generation variable compressor it is normal that it always runs. If not it means there is performance problem.Check if you have blocked the ventilation of the appliance.Check the minumum distances for the installation in the user manual.Somehow temp must fit to your set and the appliance is always working to reach the target.
TT16DKXSQ04 refrig
Having the setting up too high, don't see that mentioned, try a lower setting. What temp is the unit reaching, if less than what it is calling for it will run forever, if warmer than normal, perhaps you struck a refrigerant line when cleaning and there is low freon and system is trying to reach a temp it can never reach due to low freon?
Otherwise the sensor is bad, making it try to reach a temp out of range of unit.
Sep 08, 2014 | Refrigerators
The freezer are good but is not cooling in the refigator
Check the fan motor in the freezer.It may have stopped working.
It blows cold air to the fresh food side.
Set the freezer temperature control to a lower number.
Check the back wall inside the freezer for ice buildup on the wall.
This would be a sign of a defrost failure.
Mar 30, 2011 | KitchenAid KSRP25FSBK
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
We have a refig.. with top freezer. Freezer works fine, refrig. is not working, motor still runs when turned up. About 8 years old. What could be wrong?
Make sure the fan in the freezer is running. if it is . More than likely the vent has ice in it. take the bottom out of the freezer and you can get to it. throw the ice and then check the drain. is right behind the vent.
Sep 23, 2009 | GE Refrigerators
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Jan 28, 2009 | Frigidaire FRS26R4A Side by Side...
Freeze slite cool but refigerator is not cool at all
Sounds like a defrost system failure. This could be the freezer fan, heater, timer. You need an OHM meter.
You can manually defrost the freezer with a hair dryer that will get it working for a couple of days. Remember there is a lot of ice behind the freezer back wall, you can only see the tip of the iceburg.
Jan 23, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
