Question about RTO Basement Watchdog Sump Pump
Won't stop beeping
I just installed a watchdog fallowing all instructions a day or two later it started beeping and the light was flashing saying to check the connections or maybe defective battery. did i get a bad battery?
2 Suggested Answers
glc1620
  • 8 Answers
SOURCE: watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
Posted on Sep 10, 2012
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Watchdog sump pump want stop beeping
Sep 10, 2012 | RTO Basement Watchdog Sump Pump
I just got an oil change in my 2003 vw jetta. The next day my oil light started flashing and beeping and won't stop. Should I be worried??
yes- check your oil level - sounds like they didn't fill completely or something is loose and leaking oil out
May 24, 2011 | 2003 Volkswagen Jetta TDI
The beeps start slowly then get faster and faster - it beeps for over a minute then stops. 5 mins later it does it again, then again. then nothing more until say the next day. The console is is standby...
i think there mite be som problem with settings...did u use any unauthorised cds or internet program...or u mite used it for a long time..u try this site to solve your problems click hear
Nov 04, 2010 | Sony Playstation 3 (PS3) Console
On top is it say windows boot manager windows failed to start.a recent hardeware or software change might be the cause.
hi, go to start , choose support and help , find restore the system ,and fallow instructions, you must be choose 1 day before or from what day you have this problem , and select tha date , fallow the instructions easy, restart the system and try again
Sep 02, 2010 | Computers & Internet
T642 getting a watchdog error with no other error codes
Hi, the way to fix this problem is by updating the firmware on your printer. Go to support.lexmark.com/printerfirmware and use the following keycode: lsstp240 that will download the firmware that you need to flash to your printer. To flashed you can do the following. If your printer is connected to the network then go to a browser and where you will type the Url (ex www.fixya.com) type the IP address of the printer. Then go to configuration, then go to Update firmware and browse for the firmware that you just downloaded and hit send. The printer will start beeping and saying updating firmware do not turn off. Once the firmware update is complete then the printer will restart and you should not see the watchdog error again.
Dec 30, 2009 | Lexmark T642 Laser Printer
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Dryer says locked
The Operating Instructions say this:
Control Lock
To avoid having someone accidentally start or stop
the washer, press OPTIONS and Select at the same
time and hold for about 10 seconds until the
(Control Lock) lights up. “LOC” will be displayed
alternately with the estimated cycle time. Turning
the Cycle Selector knob or pressing any button
will produce flashing indicator lights and/or beeping.
To unlock the controls, press and hold OPTIONS
and Select for about 10 seconds.
Oct 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
RTO Basement Watchdog  Sump Pump Logo
1,584 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
