Question about E-Machines eMachines Desktop PC
Emachine desktop The computer worked fine one day and the next day when we went to turn it on it would not power up. The monitor comes on and on the monitor screen it said monitor working fine check hard drive. Well I can't check anything because the tower has no power. The light around the button doesn't come on and you can't hear any kind of fan starting. Called emachines and the only thing they could tell me was to change outlets, did that, turn power off (no power) leave unplugged for 3 minutes push the power button and hold it for 30 seconds, Nothing. Took the computer to a repair shop and he said it was the motherboard and would cost $130.00 to fix. Then called and said it would cost $300.00. We picked it up with no repairs being done. This computer is less than 3 years old. It belongs to my mother who does not down load stuff off the internet only uses it really to check her email from friends. Any suggestions? Is it junk?
    Problem Solver:
  • 15 Answers
Re: Emachine desktop
I understand that your cpu is not turning on and the repairer confirmed that it is the issue with the mother board. I suggest you to please check the smps fan spinning or not. If its spinning then then the issue could be with the mother board. If not try changing the power cables.
Next check whether your cd rom light is glowing. Even if there is an issue with the mother board, as the power is supplied by the smps the light  should glow if the light is not glowing its clear that something must be wrong with smps.
Please provide us the result of the above steps so that I could assist you further.
Posted on Nov 08, 2007
4 Suggested Answers
  • 5660 Answers
SOURCE: Need wiring connection diagram for
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Posted on Oct 18, 2010
  • 33 Answers
SOURCE: i have a emachine w5243
try unplugging the actual drive out of the computer tower and booting it up then shut it down and plug it back in
God Bless
Posted on Mar 29, 2008
  • 2600 Answers
SOURCE: Reformatted eMachine W3107, recovery disk contains no drivers
Here is the link to your downloads file at E-Machines. All your drivers are here. Download and install them. ParrotHead PC Repair
Make sure you copy and paste the whole line in your web browser's address bar. Click on downloads and there you go..... Series&model=W3107
Posted on Sep 11, 2009
  • 63 Answers
SOURCE: eMachine T6522 monitor says
This could be an issue of a video card gone bad. I have experienced the same issue firsthand. This could also mean that no RAM is installed. If you have been using this computer previously, the second option is probably not even an option.
If you have another computer available, please try plugging the monitor in to that machine to test. If it works, your Video Card is more than likely toast.
But not to worry, you should be able to find a new card for that machine. I believe it will be a PCI Video Card, which may run you anywhere from $20-$100 depending on what you purchase. Please consult with eMachines before ordering a new card. Some will not work with your machine.
I hope this helps you out. Have a great day and please don't hesitate to ask any further questions regarding this issue.
Posted on Feb 26, 2010
Testimonial: "Will definitely ck this out...sounds possible."
0 characters
3 Points
My emachine has power but is not working
Hi friend,
Power is coming in system thats means your system motherboard & SMPS is working fine,There was a problem with RAM,RAM is faulty,please change it,it is fix under your system motherboard,this is esly removeable,
Jan 30, 2010 | E-Machines eMachines Desktop PC
How to connect emachine flat monitor to my computer?
It sounds as if you are missing the power cord for the monitor. If the cord did not come with your monitor/PC, you can pick one up at any Radio Shack or electronics store. If you could forward me your eMachine model number as well as the monitor model number, I will see if I can better solve this for you without you having to spend anymore money.
Best Regards,
Franklin, C2Solutions
Jul 21, 2009 | E-Machines eMachines Desktop PC
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
I have a emachine w2646. I went to turn it on and nothing. The green light is on and the monitor works. I switched to plugs and even went a brought a new power supply. The green light only come on. What...
you could replace your video card.but it could be a motherboard problem as well.if your card can be removed try it in another could also try resetting the computer bios.
Mar 01, 2009 | E-Machines eMachines W2686 PC Desktop
Cpu turns on but nothing else does.
Well, when my emachine did this, I was informed the "power toggle" was "gone" and that basically it would cost more to fix than to replace. I suggest you have this looked at as I suspect you will be given similar information.
Wish I had better news. Good Luck!
Feb 19, 2009 | E-Machines eMachines Desktop PC
Emachine tower unresponsive
Unplug the Monitor, and attempt to reconnect a seperate monitor to test. If that monitor works properly, then the problem is your regular monitor. If you do not have another monitor, Try unplugging the power from the wall jack to the tower. Then plug into another port, the reason the computer doesn't turn on is because the power outlet may be running but at a lower voltage then what is required for the computer to run at its full potential. If theese both fail, Try opening your computer and check if anything is blown out.
Feb 07, 2009 | E-Machines eMachines Desktop PC
Emachine T3414 monitor
Turn off the computer and monitor. Disconnect the monitor. Turn on the monitor. You should get some indication the monitor is on, if not it is probably dead.
If the monitor seems to be on, try to enter the menu by using the buttons or knobs on the monitor. If the menu comes up, the monitor is probably good and you have a computer problem.
If you think the monitor is bad, hook it up to an operational computer. If it works, you definitely have a computer problem; if not the the monitor is definitely dead.
Either way try to have the problem resolved under the warranty.
Nov 01, 2008 | E-Machines eMachines Desktop PC
Emachine w2686 no display when boot up
Couple things to check. First, check with different monitor. Their monitors are usually build by KDS and I think there was a bad series out there. Also check for any beep codes through speakers on startup, this can tell you bad ram or bad video out. Also try unplugging computer and removing CMOS battery inside (watch like battery). Lastly, If non of the above, a bad processor will allow the computer to come on but no beep, no boot, no nothing but fans and green power light. Hope this helps a little.....
Apr 25, 2008 | E-Machines eMachines W2686 PC Desktop
Emachine wont start up
nope..that's not an the power button showing a solid color, if applicable?
Feb 20, 2008 | E-Machines (T2958) PC Desktop
E-Machines eMachines Desktop PC Logo
156 people viewed this question
Top E-Machines PC Desktops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you an E-Machines PC Desktop Expert? Answer questions, earn points and help others
