Question about Craftsman Garden
Won't start...still almost new. Has fuel and new plug but no go.
  • 211 Answers
Hi
check the spark first
bye
Posted on Oct 07, 2009
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 14, 2013 | Ducati Motorcycles
1986 LeSharo Winnebago (renault 4 cyclinder engine)
I have a 1989 LeSharo & the fuel filter on it is mounted on the frame under the driver's seat, just back of the left front wheel. Hope this helps. I am in need of advise on why mine won't start. Has always started/ No problems til now. Have new battery, fuel filer & plugs.Tries to start, but won't. Cleaned the distributer cap, new gas, even "tune up in a bottle". No progress. Help appreciated!!! Thanks!!
Aug 01, 2012 | Moeller InLine Fuel Filters Replacement...
1999 audi A 4 Quattro won't start
If you have fuel as you say then the fuel pump relay is not the problem.
Jun 22, 2012 | Cars & Trucks
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Murray riding mower won't starter, new solenoid, new spark plug and trying start it from the start turn over but won't start and try from the solenoid still no go.
You need to pull the spark plug out, connect the spark plug wire and ground the plug to the motor and see if you have spark. If you have spark (bright blue) then it is a fuel problem. A yellow spark is and indicator of a coil issue.
Aug 25, 2011 | Garden
1996 ford tauras wont start
Sounds like a fuel problem. check fuel pressure and then check for power going to the pump.Verry likley needs a new fuel pump.
Dec 28, 2008 | 1996 Ford Taurus
Garden Logo
46 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
