Commercial central air with Carrier thermostat on wall. Buttons do not work. No air flow from overhead vent.
The thermostat for other part of office is working without problem.
This room may have had loss of power (when lights are left on, overnight security can turn off by flipping circuit breaker).
I don't know the model or year but it has the words:
"cool" on left with up and down button above and below the word "cool"
and "warm" with the same type buttons on the right side of the thermostat. There is a LED window in the middle alternately flashing these three things: 02 HF, 90 60 and the current temp.
SOURCE: model JBP79 FFFcode
FFF
Control Error, Failed EEPROM
Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
