Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush/bristles won't rotate - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • 344 Answers
Probably a broken drive belt, fairly cheap and really easy to fix, remove sole plate cover to access belt, 5 minute job.
Posted on Jun 30, 2009
How can I get the brush roller to work
HI, it's Jim from Crucial Vacuum!
First things first, unplug your vacuum and turn it over. Check your brush roll for any large amount of debris. This usually comes in the form of carpet fibers, or hair strands wrapped around the brush roll. Try manually rotating the brush roll, this will help unclog any hidden debris.
Take off your vacuums bottom plate, this is usually held on by two screws on opposing sides of the bottom of your vacuum. Remove the brush roll and examine the belt to see if it is applying tension to the brush roll. If the belt is loose this would cause the brush roll to not work properly.
What's the quality of the bristles on the roll? If they look worn down, or loose then it's time to replace the brush roll itself.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Jan 28, 2015 | Vacuums
Why does my brush turn?
Most likely the belt that connects the motor to the brush has broken and needs to be replaced. A relatively easy fix.
Nov 12, 2014 | Shark 12-Volt Cordless Hand Vac
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Our brush won,t spin can you help?
Most likely your brush needs to be removed and cleaned. Clean all debris that might be in the bristles of the brush. You will see a holder for the brush on each end that holds it into the frame of the vacuum. The two holders should turn freely. If they do not, spray a bit of WD40 between the brush and the holders and rotate the holders around the brush. Doing this will clear up the most common occurring cause of the problem you are facing. One other important item is the belt that drives the brush. Make sure it has not broken or stretched. If it has, replace it while cleaning the brush.
Good luck and feel free to contact me if you find this does not solve your problem.
Paul
Sep 18, 2010 | Hoover U5753-900 WindTunnel Bagless...
I have a Hoover Steam Vacuum, All Terrain, and the bristle brushes are not rotating. They appear to be seated properly and, the entire vacuum is clean and free of lint, hair etc., so everything is working...
I checked the owner's manual and the parts breakdown for your model F5807. Both showed that your model has a stationary brush strip and not rotating brushes. Is F5807 the correct model number?
May 18, 2010 | Hoover F5807 SteamVac Wet/Dry Vacuum
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
DCo7 too much suction hard to push
This suggests that the bristles on your brush roller are worn out.  When the bristles are a good working length, rotation of the roller actually helps to pull the machine over the carpet. When the bristles wear down this effect is lost.
May 20, 2009 | Dyson DC07 All Floors Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
335 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
