I have been told that I need a new main control board (not the display board) for H250PED2 do you know the part #? The heater fires up but only stays lit for a few seconds, orifices and flame sensor are good.
SOURCE: hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
SOURCE: Hayward Comfortzone pool heater pilot will stay
check for continuity at all control and safety components,i.e. press switch,high limits,thermostat,on/off switch and flame roll out switch
SOURCE: hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
SOURCE: hayward pool heater pilot won't stay on
a short circuit in the heater wire will cause an immediate loss of all flame, pilot and main; check the wiring diagram and make sure your pilot wires go to the PP and PP/TH terminals; make sure the terminals are clean and the connection is good; you are dealing with .320 volts DC, any bad connection drops the voltage below the required minimum.
SOURCE: MY HYWOOD h SERIES POOL HEATER DOES NOT LIGHT. IT
are you sure the code isnt FO , which would indicate flame sensor failure.usually can be solved by removing and cleaning fl sensor with fine emory cloth.since htr is calling for heat ,pressure switch does not need adjusting
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
