Question about KitchenAid KESC307 Electric Kitchen Range
Kitchenaid slide in range arg7102w 2 burner not working right
2 burners not working right. Sometimes they work. but have no idea what temp they are on and have trouble turning them off. Have tried changing out knobs and tightened the metal posts that knobs fit on. Help Thanks
  • Anonymous Mar 18, 2014
    when turning the knob burner does not shut off
  • 833 Answers
First...if the flames on your burners are predominantly not use this stove! There is a strong danger of carbon monoxide.
Keep windows open while performing the tests below.
2 burners, huh? This is a gas unit. When you say trouble turning off and you say you have issues with temperature, I'm wondering why you've got issues like this. I'm inclined to believe that you've got clogged burners here or that the valves are gone. Clean the burners. The flames should be blue...with barely any yellow in them. If not, you've got blocked air supply. Clean it out. Never use abrasive cleaner like Comet here! If the burner heads are very corroded replace them. What about the valves? Do you hear gas flow after the valve is turned off? If not, it sounds like the burners are blocked. If so, the valves are probably have used them much more than the other side. Can you change the burners/tubes left to right? Try it and see what happens then.
Posted on Dec 03, 2007
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
One of my kitchenaid cooktop burners does not work
go to could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Oven glass shatter on kgst307gwh0
You would need to contact Kitchenaid about any possible product issues
Mar 05, 2017 | KitchenAid KGST300 Gas Kitchen Range
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
183 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
