Question about Electrolux EW30DF65GS Dual Fuel (Electric and Gas) Range
Cabinet clearance required for Electrolux Dual Fuel Range
I've purchased an electrolux dual fuel slide in range. I'm also having new kitchen cabinets built and installed. Our local gas company requires an 18 inches vertical clearance between the cabinets and the range, unless the manufacturer has more stringent requirements. Are there any manufacturer's specifications for clearance vertically, between the cabinets & cook top, as well as horizontally from the cabinets to the right & left of the range
Thanks
Laurie
5 Suggested Answers
SOURCE: Electrolux Slide In Electric Range doesn't fit to the wall?
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Posted on Nov 30, 2008
  • 56 Answers
SOURCE: BRAND NEW range. 1 burner will not light!
Look for foreign material in the burner assembly.
Posted on Mar 28, 2009
SOURCE: our electrolux 30
got the warranty to kick in thank you for the support
Posted on May 19, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: electrolux dual fuel oven will not heat after self clean
    The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
    Posted on Sep 04, 2012
    I have an Electrolux 30' dual fuel slide - in range that the control lights have gone off. The gas burners still work so I know it is not the electricity going into the range. Was is possibly wrong.
    Make sure the plug is on all the power behind the stove has power the electricity does not hold the gas going into the burners at all you will always have gas on the top burners the only one that gets held back by to the Tri-City is the oven so if you got no power at all to make sure there's power on the plug behind the stove
    Dec 02, 2017 | Electrolux Kitchen Ranges
    Blue lights flashing can not get to reset
    Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
    Oct 26, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
    After a power outage. All the lights on the range are blinking/flashing, how do I turn them off? Everything still works. Just can't turn off lights.
    Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
    Oct 18, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
    Electrolux dual fuel range 316471210 self clean remove racks message displayed and cannot proceed
    Hi friend, thank you for your inquiry!
    I understand that you are receiving a "remove racks" message on your Electrolux range. The oven racks and supports must be removed before the self-clean will initiate or the control will not allow the self-clean to turn on. I hope this is helpful. -Matt
    Sep 04, 2014 | Electrolux Kitchen Ranges
    Electrolux dual fuel oven will not hold a steady temperature.
    Good Morning Friend,
    I understand your Electrolux range, model# EW30DS65GS, will not hold a steady temperature. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any oven cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    Jul 04, 2014 | Electrolux EW30DS65GS Dual Fuel (Electric...
    Oven door won unlock
    I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
    Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
    Electrolux dual fuel oven will not heat after self clean
    Sep 02, 2012 | Electrolux EW30DS65GS Dual Fuel (Electric...
    Open Questions:
    Electrolux EW30DF65GS Dual Fuel (Electric and Gas) Range Logo
    334 people viewed this question
    Top Electrolux Kitchen Ranges Experts
    Craig Butler
    Craig Butler
    Robert Plante
    Andrew Taylor
    Andrew Taylor
    Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
