Question about Trendnet TEG-224WS 24-Port Ethernet Switch (710931501919)
Trouble connecting some computers to my network
Dear sir. I have some trouble connencting my switch to my network. It is a lan, so i share internet and an application called SAP. The computers work for a little while, but suddenly, internet falls and of course, SAP too.What should i do? P. S.: My ISP uses an IP and two DNS, for internet connection.
  • 118 Answers
Can you post your ip addressing and some more info
Posted on Feb 07, 2008
Network Troubleshooting in windows
<p>Some Time Network trouble shooter faced some problem in but they can't solve out where is the exact problem. Yes it create critical situation some time to find out where the problem is. In windows based OS have a feature to take out problem. Network trouble shooter is the feature where we can recognise the trouble of hardware, software or network. Here I will describe about <span>how to troubleshoot a Windows XP-based home network. Usually it will describe also about a network structure, how to use the Home and Small Office Networking Troubleshooter, and how to troubleshoot basic connectivity, and how to resolve file and printer sharing issues. If you have problems with your home network, follow the steps in this article to help isolate and troubleshoot the configuration of your home network's basic connectivity, and file and printer sharing. First, try to identify and resolve the issue by using the following steps. </SPAN><br> <p><span><span> </SPAN></SPAN>At <span>first you have to know the kind of network structure that using there. If you are not sure, go to the "Home-network structures and their configurations" section. To identify the problem first </SPAN><span>Click starts and then click </SPAN>Help and Support<span>. </SPAN><span><span> </SPAN>After that </SPAN><span>Pick a Help Topic, click Networking and the Web. </SPAN><span><span> </SPAN></SPAN><span>Under Networking and the Web, click Fixing networking or Web problems, and then click Home and Small Office Networking Troubleshooter. </SPAN><span>Answer the questions in the troubleshooter to try to find a solution. </SPAN><span>Before you troubleshoot home networking issues, first determine the network structure you are using. The network structure is the arrangement or mapping of network elements such as links and nodes, and the physical connections between them. There are several common home-network structures.</SPAN><br> <p>If in that Lab the computers are connected to a hub, where only one computer has Internet connection shared by using Internet Connection Sharing<b><span>.</SPAN></B><span> </SPAN><span>In this configuration, the computer that shares the connection generally assigns IP addresses to other computers on the home network. The computer that is sharing the connection will have IP address configured for the adapter that is connected to the home network. Other computers on the network will have addresses in the range 192.168.0.<span>x</SPAN>, where <span>x</SPAN> is a number between 2 and 254.</SPAN><br> <p><span> </SPAN>If t<span>he computers are connected to the Internet</SPAN> through a broadband connection, then<b><span> </SPAN></B><span>this configuration is also known as an edgeless network. In this configuration, the computers on the home network each have an IP address that is provided by the Internet service provider (ISP). The addresses that are used vary, depending on the ISP. </SPAN><span></SPAN><br> <p><span>So Network trouble shooter is very useful and easiest process to identify or troubleshooting a network problem.</SPAN>
on Mar 24, 2011 | Microsoft Windows XP Professional With...
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Problem with internet when using LAN
You have to set-up proxy setting for the same thing
If both your system is having Win xp then please activate internet connection sharing which is there at the network properties
or you can install 3rd party proxy also
just chek with ping uitlity weather it can ping with each other
Mar 14, 2009 | Edimax ES 3108P (ES-3108P) Networking...
Can't share internet over lan
You must share your internet to other computer using your lan connection in able other PC can open internet wondows.To do this
go to my network click set up home and small office network then follow up wisard set up before you close set up insert your cd windows installer e.g. xp or vista click additional task,click home and small office network again from cd follow wizard then click finish,then insert your cd wondows installer to other computer and repeat procedure on set up home and small network restart your PC everytime you install internet sharing,be sure one PC will assigned as server
Mar 06, 2009 | Computers & Internet
Sharing internet to lan networking
dear sir
plese go to the following site to sharing internet to lan networking..
Dec 10, 2008 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of and a subnet mask of
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
To share an internet connection, you need to have two network connections, one for the internet connection, and another for your network.
If your DSL has a USB connection, plug it into one of your computers and then then go through the network setup wizard, from there it will walk you through sharing an internet connection.
If all the computers have wireless, you can set up an adhoc network, and share the connection that way.
Honestly, the easiest method would be to go out and buy a router.
Aug 24, 2008 | Microsoft Windows XP Professional With...
The trunk port of the switch is meant for cascading the switch i.e. you can connect another switch to that port for adding more computers.
For connecting to a multihomed PC (with 2 lan cards) Please type in static ip address to the lan card that is connecting to the switch and alos add static ip adds to all the other computers taht are to be connected for sharing. Then share the internet connection through the other lan card.
Please write to for more details
Oct 28, 2007 | Cnet CNSH-1600
Setting up 16 port switch
Dear This is the step You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved: Take stock of your existing hardware. If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host. Decide what type of network technology you wish to use. Make a list of the hardware you need for each computer. Install the network adaptors and install your modem on the ICS host computer. Physically cable the computers together. Switch on all computers, printers and other peripherals. Make sure the ICS host is connected to the Internet. Run the Network Setup Wizard on the ICS host. Run the Network Setup Wizard on the other computers on the network. Let's take that step by step. 1. Take stock of your hardware Note each computer's location and its hardware, including peripherals such as printers and modems. 2. Choose your ICS host If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host. The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps. Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall. 3. Choose a network technology The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers. If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead. Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch). If you have a high-speed Internet connection, a high-speed router is a good option. The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home. If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range. 4. Make a list of hardware needed Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP. 5. Install the adaptors Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each). 6. Cable the computers Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route. If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors. 7. Switch it on Switch on all computers, printers and other peripherals. 8. Connect the ICS host Go to the ICS host computer and make sure it is connected to the Internet. 9. Run the Network Setup Wizard on the ICS host To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue. XP's Network Setup Wizard takes much of the pain out of setting up a home network. The Network Setup Wizard will guide you through: Configuring your network adaptors (NICs). Configuring your computers to share a single Internet connection. Naming each computer. (Each computer requires a name to identify it on the network.) Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network. Sharing printers. Installing the Internet Connection Firewall to guard you from online attacks. 10. Run the Network Setup Wizard on all computers To do so: Insert the Windows XP CD in the first computer's drive. When the XP Welcome Menu appears, click Perform Additional Tasks. Click Setup Home Or Small Office Networking and follow the prompts. Repeat steps 1 to 3 for each computer on your network. Make sure you maintain an active Internet connection on your host computer as you proceed through this process. geekgirl.tip If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk: While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk. Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive. Double-click My Computer. Double-click 3½ Floppy (A:). Double-click netsetup.exe. The quickie XP network If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration. That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME. Using your network Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places). The Task Pane in My Network Places lets you access computers on your network and adjust settings. The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers. Sharing a printer With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.) To share a printer, on the computer which is directly connected to the printer: Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.) Click the printer you wish to share. Click Share This Printer in the Task Pane. In the printer's Properties dialog, click the Sharing tab. Click Share Name and OK. Make a printer accessible to others on the network by sharing it. Once a printer has been shared you can access it from other computers on the network. To do so: Click Start -> Control Panel -> Printers And Other Hardware. Click Add A Printer. In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter. In the next screen, select the option to Browse For A Printer and click Next. Select the appropriate printer from the list and continue with the wizard. Sharing files and folders Sharing a folder is even easier than sharing a printer: Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder. With the new folder highlighted, click Share This Folder. In the Sharing tab of the Properties dialog box, select Share This Folder On The Network. Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1. You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files. There are a variety of ways to access a shared folder. Here's one way: Click Start -> My Network Places -> View Workgroup Computers. Click the computer whose files you wish to access and then click the shared folder. You can create shortcuts to shared folders to make them easier to gdfgf
Sep 08, 2007 | Computers & Internet
Trendnet TEG-224WS 24-Port Ethernet Switch (710931501919) Logo
256 people viewed this question
Top Trendnet Computers & Internet Experts
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
