SOURCE: tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
SOURCE: crackling from set volume button makes no
Sounds like a loose connection with one of the audio/video cables inside the TV or a short. Contact a qualified service technician to do the fix.
SOURCE: The volume is stuck at 100 (max) and when I go to
It sounds like the a switch on the TV is stuck. This may just be a stuck button, or a bad Switch Board. Try moving the buttons around to stop the problem. If this doesn't work, you will probably need to replace the Switch Board.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: Hello , I have a
This is a fault in the memory as the logic gate has failed and so the control is at the highest. So you need to check on the details of the logic outputs in the processor. So please the memory output to the audio control and if the status is HIGH then the IC can be defective.
Other way out is to use a potentiometer as a volume control to reduce to the required level, control to be fitted to the output from the processor output to the analogue section.
SOURCE: Volume goes all the way down on its own on my sylvania lc320slx
The volume down button/switch on the set is defective
