When the phone answers it ask for a pin which i never set up. I have tried unplugging it, pressing the silent button and pressing the answering on/off button none of which solved the problem.
By any chance do you have call forwarding turned on? That would account for the single ring and the unfamiliar voicemail. Call forwarding is a service provided by your phone company or cable voice company which allows you to transfer incoming calls to another phone number, such as a cell phone. It's usually activated by pressing a key sequence (such as *72) and entering the number of the phone that you want to receive your calls. It's easy to turn it on and then forget to turn it off. You can turn it off with another key sequence, such as *73. Contact your phone company for the correct code.
SOURCE: I have a Uniden 5.8GHz DSS8955+1 and it's
Set your answering machine to pick up after four rings . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
