Question about Refrigerators
Water and ice pool in bottom of fridge
Have a Whirlpool mark I, model eet-222mt fridge. water and ice are pooling in bottom of fridge. How do I unplug drain?
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jun 30, 2009
What is wrong when the icemaker leaks into the inside of the fridge
ok unplug frig open freezer door empty ice let freezer door stay open for a few hours ice has formed where the ice cube water comes into it. ice built up and water sprays every where but where it should
Aug 19, 2014 | Refrigerators
How do I remove the back wall of freezer on samsung rb195acwp
Annonymous, what problem are you trying to solve? Is the water at the bottom of the refrigerator because the fridge is not cooling? If that then unplug the fridge, Keep the fridge and the freezer doors open after salvaging food items. Keep it unplugged for about 12 hrs and any ice buildup in the back wall will melt. You will see a pool of water on the floor. Clean that and the inside of fridge and freezer. Re-connect. You might get lucky!
Jul 29, 2014 | Samsung RB195ACWP Bottom Freezer...
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Water keeps pooling up on the bottom of my fridge and freezing
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | General Refrigerators
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Fridge is leaking water from top of fridge and water in bottom of fridge
The defrost drain hole is plugged. you must open that and then the water from defrosting will not pool up below the crispers in the bottom of the frig. Generic ice box Manual and more Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Whirlpool Refrigerators
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
