Question about Canon PIXMA MP160 All-In-One InkJet Printer
My canon pixma mp160 printer has an error code of "e3".
If fixing this requires disassembly (taking apart of printer), please tell me how to take it apart as clearly as you can. Thank you.
    Sniper:
  • 84 Answers
Try the Canon support site. Type Canon support into your search engine.
Posted on Jun 30, 2009
  • 75 Answers
Opening the printer can void your warranty, if it is still under warranty bring it back to the supplier of your canon e40
Posted on Sep 24, 2011
    Problem Solver:
  • 20 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi1
Posted on Sep 05, 2009
Error code 3 on canon mp 198
Hi
Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Pls vote us to keep us alive
Nov 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
MP160 E3 paper jam error, when it's not really a paper jam. Help!
Small pieces of debris can stop your printer in its tracks.
Take a flashlight and look to see if you can find anything and then remove it.
Get "canned air" at any computer or office supply store and blow out everything you can in the printer. You may be amazed at what comes out.
Nov 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Describe your Canon PIXMA MP160 All-i have a
hi,
pow-e-r-18
Jun 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My roller dont take in the paper
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 on Pixma MP160
Looks like there is something stuck in the insides of the printer preventing it from running to one side. A small paper clip, Ball pin etc., can cause this. You might have to take it apart and look for it. I had fixed a similar problem recently and the stuck object is "HAIR BALL!"
Jun 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160,error code e3
hi,
587
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
490 people viewed this question
old marine
old marine
