Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Tryed that Idid what dcolla told me to do whitch was to replace the battries and i did but the same problemi cant get 6 blocks out of my wheelchair could it be that something is draining the power from the battries or do i just have to live with the problem because i put the same battries into my Ranger scooter and i can go 7ml/pr/hr and 15miles on one charge.
  • 103 Answers
You need to have a trained tech do a full diag. of the chair. The motors or brakes are pulling to much power.
Posted on Nov 10, 2009
How often can you charge the battery on a Invacare ATM
Charge as required , Battries usual to last Max 5 years ( they don't make them like they used to ) Bottom line , Battries can DIE at any time . so use / charge then untill thet will not hold a charge.
Mar 12, 2015 | Invacare Health & Beauty
If it cant be reset how do i get it to go forward it does everything else it goes backwards and up and down but not forward and the scooter store went bankrupt so noone answers the phone
Disconnecting the battery for 15 minutes will reset. But, its probably the joy stick. You can try to take apart and clean the contacts but, you probably will have to replace it or the board.
May 08, 2014 | Quantum Edge 6 Wheelchair - Used Electric...
I have a jazzt 1103 power chair, I havent used it for about 6 mo and the battries went dead and wont take a charge anymore do you know about it thanks
Recharageable batteries need to be kept charged and if left uncharged for a long period they most likely no longer work.
You need to replace these batteries.
Mar 17, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Where do you get battries
Try Batteries Plus, Battery Warehouse or Interstate Batteries. You can also contact a local Durable Medical Equipment provider or a small engine repair shop. Check your owner's manual for the battery type but MOST LIKELY you will need a U1 12 volt 33 amp battery and you will need 2 of them. CHECK YOUR MANUAL OR CURRENT BATTERY CASE TO BE SURE.
Aug 05, 2010 | Electric Mobility Tuffcare Challenger Dx...
My calculator cant be switched on completely.
check the emergancy battry which is right next to the battry and replace all the battrys. if u still have the cable, try to find an update on the T.I website
Mar 08, 2010 | Texas Instruments TI-83 Plus Calculator
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
The joystick will display a sequence of flash codes. Count them and find the count here: This could be several issues, But the flash code will tell you for sure.
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Mar 07, 2010 | Ctm HS-2800 Power Wheelchair
Just purchased it used. Both battries show
If the horn won't work, the batteries are dead. If the charger is showing green lights, most likely the gel inside the batteries has gone solid from the chair being stored for a while. Replace both batteries with type U1, 24v, 33 amps and see if that will clear the problem. The fuses are regular automotive type fuses.
Mar 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Battrie wont last
You probably need to replace your batteries again most batteries in a owc need to be charged 12 hrs a day for the first month at least to build up the capacity if not they will slowly dwindle and wont last long and will need to be replaced
May 29, 2009 | Pride Mobility Products Used Jazzy...
New battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Mar 03, 2009 | Jet 3 Ultra Power Chair
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
128 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
