Question about Freezers
Commercial freezer (Randall) with a Ranco thermostat, not cooling
I have a commercial freezer (Randall) with a Ranco thermostat. It won't get any colder than 25-30F. There are two adjustment knobs, but I don't know what to do. Please help!! Thank you.
    Sergeant:
  • 340 Answers
Clean condenser? is evaporator free of ice? may need defrosting or low on freon. Tom
Posted on Jul 01, 2009
I have the same problem, i deice every week but it is either too cold or not cold at all. We have it hooked up to a bar, and the wines and beers are never cold enough.
Posted on Jan 03, 2010
The freezer won't keep normal -10F temperature, but stays at -35F to -40F at all times
Thermostat or start relay is defective and causing the compressor and fans to run all the time. Here is a manual for all models=> HERE
Sea Breerze
Feb 10, 2013 | True 49 cu. ft. / 1388 liter Commercial...
Freezer not freezing acting like refrigerator
Either the thermostat went bad or the refrigeration system has a leak and you are low on freon....that will also cause poor cooling..
heatman101
Sep 15, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Freezer stopped working for a period of time while we were gone for 4 days...set house thermostat to 86 degrees
Is this a commercial freezer? If so, it might be because you don't have proper ventilation for it. Commercial units put off a lot more heat than residential units. Turning the thermostat up to 86 degrees will make it even more difficult for this unit to not overheat.
Sep 07, 2010 | Freezers
Do freezers have a thermostat
If the unit is a bit overcharged it will only go so low and then not cool any lower....you could try to remove a bit more charge and then see what happens... also check to see and make sure that the low press. switch is not cutting the compressor off...as the temp. drops so does the press. and if the switch setting is too high it will cutout to soon...
So... if the compressot runs continuously then drop charge...if it is cycling then sheck the switch...
heatman101
Jul 28, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
hope answer the question.
thank you.
Jul 05, 2010 | Frigidaire Freezers
The temp only goes down to 30 farenheit. the thermostat control knob is set to the coldest position. is the thermostat faulty or can it be adjusted?
Check list:
Fans running
Compressor cool to the touch
Not short cycling (low freon)
coils cleaned
no air restrictions
If all of that is good bypass the control
see if it gets down to 0
If it does replace the control
May 25, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Won' stop making ice
most likely the bin thermostat is not calibrated correctly or is not making contact with the ice. The unit should shut down within 5 to 10 seconds after ice makes contact and has not entered the freeze cycle.
Start there and if this does not resolve, let me know and we can get into more indepth things.
May 10, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Freezeing up, not cooling
Without knowing if it a freezer or a cooler I will have to guess. Could be caused by a few things. I'll list them in order of the one I think is the most common reason.
Cooler
  1. Door gaskets or someone left door open for a time.
  2. Thermostat set to low.
  3. Low freon
  4. expantion valve out of adjustment or needs replaced
Freezer
  1. Defrost not working (Will have heaters with a timer)
  2. Low on freon or expantion valve
Oct 13, 2009 | True 23 cu. ft. / 651 liter Commercial...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Freezers Logo
598 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
