Question about Electrical Supplies
New Onan 4000 watt gas RV generator cuts out
Hi have a 4000 watt gas rv generator thats about 2 yrs old with only about 40 hours on it. It runs perfect in the driveway (sea level) with the AC full blast but when we took it out last weekend 105 degrees and 2,400 foot elevation it would run for about 5 minutes cut out. However when the generator would shut down we would could smell raw gas. I checked the fuel line all the way from the tank to the engine and no leaks and check the carb manifold to see if there were any air leaks but could find nothing. Only seems to die when the AC is on in the heat? Can figure it out?
  • chyenviro Jul 07, 2009
    Hi Protek480,
    That makes more sense, kinda what I thought it may have been but wasn't sure. I'll contact Onan and see if they had a jet kit. Thanks really appreciate the help!!!
    President:
  • 1,723 Answers
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
Posted on Jun 30, 2009
  • Craig Butler
    Craig Butler Jul 07, 2009
    Some Onan units actually have an adjustment knob you can set for different altitudes, depending on your model.
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
I HAVE A 5.0BGE ONAN GEN SET IN MY RV IT RUNS BUT THERE IS NO ELECTRICAL POWER TO RV ALL FUSES AND BREAKERS OK. ANY HELP APPRECIATED
Possible solution: if it's been sitting idle for some time, you might need to flash the windings. see this link:
http://www.endtimesreport.com/dead_gen.html
If you're uncomfortable doing it yourself, your Onan dealer can do it in 10 minutes.
Don't forget to check the circuit breaker on the generator itself!
Sep 01, 2011 | Watts Onan Portable Generator - 4000 ,...
RV Onan 4000 runs fine but not putting out enough voltage to run anything
Not sure how to set it up but you can take it and have the voltage turned up on your generator or the voltage regulator is out.
Sep 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
316 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
