Question about Thetford Norcold RV Cooler/Freezer
My Norcold two way fridge is blinking five times even after I reset . Burner is working is there anything I could do to fix this problem
    Genius:
  • 1,406 Answers
Is it dead level? Does it have enough ammonia?
Posted on Aug 11, 2014
Norcold model N302 3R fridge wouldn't light on propane.I cleaned burner and ofice and now it lights easily but keeps going out.
Igniter could be bad. You have to remember the flame will go off and on many times a day as the thermostat kicks the temperature on and off. Igniters do not last forever.
May 24, 2017 | Refrigerators
Norcold fridge berps and display says No flame
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Mar 25, 2013 | Thetford Norcold DE0051 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
My norcold N841 will not cool on AC or Gas it has power and the gas will fire up
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Sep 02, 2009 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Reset Norcold 'N61 Series' Fridge after lockout
Hi Lynn1965,
I'm Harvey the Master Plumber.
Yor problem is: Please help! Your brother phoned you on his cell from up north. He's supposed to go hunting tomorrow, and is having problems with his fridge. The nearest dealer is 5 hours away, and he's very upset.
The fridge went into lockout mode after accidentally resetting twice. Now, the lights flash, and fridge doesn't work.
Please advise how he can fix this problem himself. You both would greatly appreciate it!!
First, unplug the unit for 10 minutes. That should reset it. If not, ask if he can here the compressor motor. If not, then he has a compressor or electrical failure inside. If yes then look to a bad thermostat.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Thetford Norcold® Model DE0061
Norcold RV Refrigerator
It sounds like the relay could be stuck closed on the electric side of the board. This would not allow the element to stop working. Sometimes resetting the board will fix this problem if it is still under warranty they will cover both the board or the resetting.
Aug 07, 2008 | Refrigerators
Norcold RV Refridgerator N611
Go to www.bryantrv.com and go to "service documents" and download the manual for your model "Norcold N Series". It says that 5 blinks then a pause means "no cooling detected by controls" see page 21 & 37.
Jul 08, 2008 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
288 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
tom wright
tom wright
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
