Wireless network not working . network controler driver not installed
    Scholar:
  • 31 Answers
I recommend uninstalling all wireless network adapters from Control Panel, System, under Network Adapters, right click on the adapter, and click uninstall, This should reinstall your drivers to a working state. Also, check msconfig by going to Start, run and enter msconfig.
Make sure Normal Startup is selected, and than restart your PC.
Posted on Jun 30, 2009
My wireless cannot work. the network controller has a yellow sign
you need to install network contoller driver
insert your cd driver
at device manager, right click at yellow sign then chose update driver
follow the instruction until finish and yellow sign disappear
try to connect to network
Mar 24, 2011 | Acer Aspire 4315 Notebook
Just purchased a NETGEAR wireless N WNA1100 and once it installs the software, it just quits...the wizard puts an icon on my desktop that when i click, shows busy icon, then stops, and the wizard (after 3...
Try to update the driver manually
go to your device manager and go to "network adapters". if you see the adapter and it says that it is working fine, just try to connect manualy to the network.
If you see "network controller" under other devices. right click on network controller and click update driver. select manualy update the driver. browser for the drivers inside the disk and install it into your computer. after that, you'll be able to connect to the wireless network.
Sep 18, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
Where is the 'Wireless Switch' on the IBM T42
The T42 has a bulit-in wireless network adapter and a LAN network card. T42s most likely have an Intel wireless card or less likely a Cisco wireless card.
Your wireless network adapter may have been disabled in the BIOS
and/or
The drivers for the wireless network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Install the driver and you then need to configure the wireless adapter to suit your wireless router settings before you can access the Internet.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Mar 25, 2010 | IBM ThinkPad T42 Notebook
Wireless card wn5301a not working. installed in an xp machine 1.7GHz P4, 1G ram can see wireless networks & allows me to enter network key, but fails to connect
Is this a new card you've installed or have you reinstalled the OS?
First verify that the card is enabled. Go to control panel, network connections and select wireless. If the button says Enable, click it and your card should communicate.
If there's no wireless setup to enable check the driver:
Go to control panel, select system, hardware, device manager, network adapters and select your wireless card. Then run the troubleshooter to get the card to work.
If the hardware isn't there to be selected, you don't have a driver installed for that card. Go out to the manufacturer's website and install it.
Oct 31, 2009 | Computers & Internet
Problems to configue network controller in IBM T42
There are several different LAN, wireless, & modem devices that are installed on the T40 series laptops. For example, if one of the network driver or modem driver doesn't work then install a different one. Make sure you download all the various device drivers for your model laptop and the XP version of those driver.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Mar 29, 2009 | Lenovo ThinkPad T42 Notebook
I re-installed XP T43 laptop and my wireless does not work
First thing is to check if the wireless device is working. Go to Control Panel - System - Hardware - Device Manager. Click on Network Adapters. Do you see the the Wireless card?
If not in Control Panel click on Network Connections, do you see a Wireless Connection? If not you need to install the correct wireless network driver, Check the IBM site again, there should be another wireless driver (there are a couple of different wireless card installed on T40 series ThinkPads).
THEN
If you succeed in installing the wireless driver and it is enabled.
Then click Control Panel - click on Network Connections - right click on the Wireless Networl Connection - Click on Properties and check if TCP/IP has been installed, if not install it. Check TCP/IP properties - make sure it is set to Obtain an address automatically and Obtain DNS Server address automatically.
Check the wireless settings on your other laptops, use this information to configure the wireless on the T43, ie the SSID, WEP or WAP settings
You should be able to connect to your wireless router and Internet now - let me know how it goes,
Mar 13, 2009 | Lenovo ThinkPad T43 Notebook PC
No connection to internet
It appears that either the wireless driver is not installed or not configured on your laptop. If you have already installed the wireless driver then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Feb 27, 2009 | Evesham Computers & Internet
Wireless network
hi..u need to install the nerwork adapter to
make your wireless work.so first install the
network adapter to use the wireless.
try this out..
thank u..
rate me..
Feb 09, 2009 | Acer Aspire 4520-5582 Notebook
Ibm thinkpad t42 switch for wireless network
and/or
Jan 23, 2009 | IBM ThinkPad T42 Notebook
Network Controller?!
download from any early version of system most espesailly 4rm hp pavilion dv6000 or dell vostro try dis
Jul 23, 2008 | Acer TravelMate 5602WSMi Notebook
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
