Question about Refrigerators
It seems that our kenmore freezer is defrosting for no reason at all. I dont even hear the refrigerator kick on, the light is on.
  • 4,059 Answers
Is it actually in the defrost cycle. Can you see the red glow from the heater behind the back cover in the freezer. Could be stuck in defrost because of defrost timer(adaptive defrost control).
Of it could be iced up on the evaporator coils behind the same cover, blocking the circulation of air. This would be a defrost failure. check defrost timer, defrost heater, defrost thermostat
Posted on Jun 30, 2009
Kenmore model 795.71022.010 water builds up in the bottom of the freezer every two weeks I have to defrost the unit and remove the ice build up if I dont the door wont close
The fan unit behind the wall inside the freezer may have frozen over.
Even though you see no ice inside the shell of the freezer, it can still have blocks of ice behind the back wall.
So remove the 3-4 screws holding the back wall, remove it and check on the ice there.
Make sure it is completely defrosted or ice melted before reconnecting. Leave the wall off while you connect it to make sure the small fan is kicking in.
IF the fan does not kick in. you can get a replacement for $15-$20 at any fridge parts supply house. It is easy to disconnect and reconnect.
Jun 04, 2016 | Kenmore Refrigerators
I have a bottom freezer kenmore refrigerator model 596.72253200 and its making a grinding sound coming from the freezer. i found out that when the light its off on the freezer its when the noise starts
The noise your hearing is the evaporator fan. This is a sign of an automatig defrosting problem. Here is what you can do to prove that it is NOT an evaporator problem and most likely an automatic defrosting problem:
(MANUAL DEFROST)
1 Empty the freezer contents
2. Unplug the refrigerator
3. Place a fan blowing into the freezer section for about 2 hours.
(This will make a dripping water mess so be ready with the rags and the mop.)
4. After 2 hours wipe up the last bit of water mess.
5. Plug in the Freezer
6. Load freezer contents.
7. Listen for grinding noise.
My bet is the grinding noise is gone. However if you still hear it the evaporator fan motor has bad bearings in it.
The evaporator fan motor can be found here: (Item 18)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59672253200/0582/0161000/M0210209/00006?blt=06&prst=&shdMod=
If the noise is gone keep an eye on the unit after 2 days because if there is an automatic defrosting problem the noise WILL repeat.
The defrost control is item 13 this link: (Backordered)http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59672253200/0582/0161000/M0210209/00003?blt=06&prst=&shdMod=
Part number is: 12566102
I did find it in stock here:
http://www.pcappliancerepair.com/part-detail.php?affiliate_id=seabreeze&item=12566102&brand=WPL
There can be other reasons for not defrosting properly but the control is the most common failure.
Thanks for choosing FixYa.
Kelly
Sep 07, 2010 | Refrigerators
Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 26, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Will not get colder then 40 degs on the coldest setting.
Bill I would like you to look inside the freezer compartment and see if frost is building up on the rear walls indicating that the refrigerator is not defrosting properly. The part number for the defrost timer is 215846602
It is located at the bottom of the refrigerator and behind the kick plate. Remove the kick plate and turn the timer clockwise slowly until you hear the compressor stop. Leave like that for up till about 25 minutes or until the compressor restarts. Which ever comes first. During that time open the freezer and see if you can hear water sizzling or dripping indicating defrost. If this solves the problem of temperatures in the fresh food section the most likely the defrost timer will need replaced. Let me know your results so if this does not help I will be able to give other things to check, Thanks Sea Breeze
Oct 27, 2009 | Kenmore Refrigerators
Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
Jun 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator is somewhat cold as is the freezer side but the freezer side is not generating freezing temperatures. Same temperature btw the refrigerator & freezer. Model 596.50392001. Any suggestions?
Your refrigerator has a defrost timer located near the floor and behind the kick plate. Remove the kick plate grill and turn the timer slowly clockwise until refrigerator compressor stops running. Leave it there for about 30 minutes or until refrigerator restarts. During this time the refrigerator should be in the defrost cycle. Open the freezer and you will possibly hear a crackling noise or the noise of water sizzling as it drips from the evaporator to the defrost heater. If your refrigerator does not restart after this time then turn the timer again slowly until the compressor restarts. If you do this then the timer will need replaced If no defrost takes place during this time then we need to move to the rear of the freezer and unplug the refrigerator and do some test on the defrost heater. Let me know how this worked out for you. The part number for your defrost timer is 10530703
Thanks, Sea Breeze
Jun 24, 2009 | Kenmore 53642 / 53644 Side by Side...
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Kenmore side by side Model # 59507992
the relay overload plugs into the side of the compressor. its a common problem make sure you get one that matches your model number. it will fix the problem
Nov 20, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
