Question about Kenmore 63942 Dryer
Dryer heats but wont tumble/electric
Dryer heats but won't tumble, can't hear the motor turn on.
  • Kenmore Master
  • 8,220 Answers
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Posted on Jun 30, 2009
  • 4 Answers
Look for coins shorting out motor. I pulled a handful of change out of my dryer including one dime that shorted the motor. Works fine plus made money!
Posted on Jul 07, 2009
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
The heat is working but it won't tumble
tilt it back and see if the belt broke. do you hear the motor runnung?
Dec 31, 2011 | Dryers
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
The dryer heats on and off. Sounds to be laboring to turn the drum. Service tech came out and did not know how to fix or approach the problem with why the dryer heats and dries a load and then may not on...
drum roller,drum glides, or idler assemblage which is located next to motor(might be motor going out). Here is a website that will help:
for glides/roller: http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
for idler/motor: http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Kenmore 63942 Dryer Logo
160 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
