Question about Tomtom ONE XL GPS
Unable to turn TT1 on
When I turn my TT1 on, the first screen appears but stays on. I have charged the unit from the mains for 3 hours and pressed the reset button for 10 seconds. The unit will not turn off unless I press the reset button, how do I get my TT1 working again?
I had the exact same problem. I live in the US, and their service has been very good. Please call them. There is a software tool that can be downloaded to fix this.
It fixed mine fairly easily.
Posted on Jul 03, 2009
On my pt-50lc14 hdtv my screen is stuck on this message, 5v eeprom), 3.3v (gc2), tv-factory mode
Have you tried any of the reset commands?
Try these....please let me know the result:
Method 1
1. Unit power must be ON and unit must be in STOP mode.
2. Press and hold [CH UP] and [CH DOWN] ON THE UNIT for over five seconds. The unit will turn off.
3. Press [DVD POWER] to turn the unit on.
Method 2
1. Press [STOP, TUNE MODE] on the main unit and [>10] on the remote control at the same time for about 3 seconds until the message "Initialized" disappears from the television screen.
2. Turn the unit off and on again.
Method 3
While the unit is off, press and hold [VOLUME +], [OPEN/CLOSE] and [POWER] on the main unit at the same time for more than 5 seconds.
Method 4
While the main unit is on, press [POWER] on the main unit for more than 4 sec. (All the indicators will blink twice when the main unit is reset.)
Another possibility is to unplug the power cord......wait 30 minutes and plug it back in, possibly repeating the steps above. (Method 1 should reset the unit but maybe trying each of them may be necessary until it is reset.
The message appears to be one that displays when the unit is in a setup mode.
Thank you for your reply.
Jan 02, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
There are 3 signs on my cell while charging.
firmware issue. kindly download 3.1.2 firmware and and jail break it using blackrain.
to download firmware visit www.redmondpie.com for blackrain : www.blackra1n.com
use itunes to update the phone to select the firmware keep pressing SHIFT button n then press restore n browse n select the firmware file.
Feb 28, 2010 | Apple iPhone Smartphone
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
My screen went black. Worked the night before.
hi..
when the unit is on try to press and hold the reset button for 10 seconds and then release if this will not work charge the unit for 3 to 4 hours using a wall adapter and if still not work try to check if there is a latest firmware update for the gps then download it.
thank u
rate me!!
Jul 15, 2009 | Garmin GPS
MY TOMTOM XL 330-S WILL NOT LOAD PAST THE STARUP SCREEN IVE TRIED HOLDING THE POWER BUTTON DOWN BUT IT STILL JUST STAY ON THE START UP SCREEN WON'T LOAD INTO THE GPS (PLEASE HELP NEED IT FOR WORK)
There is a tendency that the unit is not properly charge try to charge the unit for 3 to 4 hours by using a wall adapter and after 4 hrs press and hold the power button for 10 seconds then release.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Tomtom XL 330S GPS Receiver
Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Mar 26, 2008 | Nokia 6300 Cellular Phone
I have a nuvi 200 that wont run when it is hooked up to a power supply
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin wont stay on
How did you charge the unit? If you have not done so, try charging in on the computer for a few hours. Sometimes this can help.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
Tomtom ONE XL GPS Logo
213 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
