Question about Kenmore Washing Machines
My Kenmore 80 series washer does not start not even let water in. I have checked the water hoses and water does come out of them.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
Kenmore washer 80 series wont stop draining
Not sure if you have already done this, but is the drain hose higher than the washer?
Jul 08, 2012 | Kenmore Washing Machines
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer will not fill. replaced
You will have to have an electrical test done. If it's not filling, that means there's no current getting to the fill valve. Have a qualified technician do an electrical test. But also, have him test the timer, too!
Dec 15, 2009 | Kenmore Washing Machines
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer will not stop filling up
one of three things,inlet water valve bad,water level hose came loose or water level switch is bad,check all tree and let me know-mike
Apr 14, 2009 | Kenmore 24902 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Sounds like you need a mixing valve.
double check for water from the source.
Jun 04, 2008 | Washing Machines
Kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
