Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Mac 3200. starts easy. dies when throttle applied. what can I DO
  • Anonymous Mar 14, 2014
    Help
    Brigadier General:
  • 4,088 Answers
Engine should be warmed up somewhat--try turning the high-speed-mixture-adjustment counter-clockwise about 1/4 turn (richer fuel mix). If this helps, the correct setting should be: 4-stroking at high speed with no cutting, but smooths out with light load (cutting wood)
Posted on Jul 03, 2009
  • 3 Answers
I've got the same plroblem, let me know if you get advice from the expert.
Posted on Jul 02, 2009
Won't throttle up.
Repost under ATV for an answer
Jul 23, 2013 | Polaris 2004 Magnum 330 4X4
02 shadow 1100 starts up but dies when throttle applied helpplease
When was the last time you cleaned the carb,and has it been setting up for a period of time
Apr 18, 2013 | 2002 Honda VT 1100 C Shadow Spirit
Yamaha tdr 125 1993 starts on choke dies with throttle
Do yourself a favor... take it to a QUALIFIED Professional and get the carb cleaned and set..,
,,. this should fix your scooter...!!
Aug 07, 2017 | Motorcycles
Brushcutter not working!
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, this is a small thing but a big problem,,hope this helps, ``
Jan 21, 2012 | Garden
Car sometimes dies in intersection
clean the throttle body most common cause of idle/decel die off. its cheap and real cheap and easy to do yourself
Apr 13, 2010 | 2001 Chrysler PT Cruiser
Trimmer dies when you apply throttle
Sounds like it might be getting to much gas. What position is the choke in during all of this? If you're giving it throttle it may be flooding itself out.
Aug 26, 2009 | Garden
2001 saturn L-series 3.0 dies after starting
You mentioned that some of the couplers for the intake runners are (were) split. I don't think that has anything to do with your problem, but it gives me an idea.
If the vacuum hose leading to your MAP sensor is also split/crushed/broken then the MAP sensor will never register any manifold vacuum. The only time that reading would be right would be when the car was at WOT. This theory alone does not explain why your car does not run, though because your car also has a mass airflow sensor. It should be able to run if either one of those sensors fails (but not both - or at least not very well with both failed). Did your car display a "check engine" light before the current condition developed? Does it have one now?
I would check the hose leading to the MAP sensor (if there is one - now that I look more closely at the drawings, it doesn't look like there is a hose). The MAP is on the top of the intake manifold on the rear bank above the cylinder closest to the driver's side of the car. It is held in by one bolt.
Can you retrieve any stored codes? Stores like Autozone will scan a car for its codes for free, but they don't make "house calls."
After typing all the above information, something new has occurred to me:
Your car has a drive-by-wire throttle. Idle speed is controlled by the electronic throttle valve. If you remove the tube that connects the throttle valve to the air cleaner, you should be able to see the throttle plate. Does it move appropriately for the amount of accelerator pedal input? For example, if you apply roughly 10% throttle, does the plate open roughly 10% of the way?
Your engine computer may just need to re-learn the position of the throttle plate. To do this, with your foot off the accelerator, turn the ignition to the "run" position, but do not attempt to start the car. After 30 seconds, the engine should begin the relearn sequence. If there are any TPS-related codes stored, the ECU will not attempt to run the relearn sequence, so you'll need to diagnose why that isn't working.
Anyway, this second option fits your symptoms a bit better than the first, and could indicate a failed throttle position sensor, accelerator position sensor, throttle actuator, wiring, or engine computer.
By the way, inability to rev above 3200 RPM may not be a problem. Some cars with automatic transmissions are limited and will not rev above a certain speed when in neutral or park. That said, if the throttle valve was not opening all the way because it was faulty, that would be a different story.
Jun 05, 2009 | 2001 Saturn S-Series
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
370 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
